| #include"STM32f10x_lib.h" //定义LCD的RS,RW,EN=0时分别是 Set_RS,Set_RW,Set_EN #define Set_RS (GPIO_SetBits(GPIOB,GPIO_Pin_0)) #define Set_RW (GPIO_SetBits(GPIOB,GPIO_Pin_1)) #define Set_EN (GPIO_SetBits(GPIOB,GPIO_Pin_2)) //定义RS,RW,EN=1时分别是CLR_RS,CLR_RW,CLR_EN #define CLR_RS (GPIO_ResetBits(GPIOB,GPIO_Pin_0)) #define CLR_RW (GPIO_ResetBits(GPIOB,GPIO_Pin_1)) #define CLR_EN (GPIO_ResetBits(GPIOB,GPIO_Pin_2)) GPIO_InitTypeDef GPIO_InitStructure; ErrorStatus HSEStartUpStatus; void Delay(u32 count) { //定义无符号长整型变量count for(;count!=0;count--); } unsigned char table[]="liushuai"; unsigned char table1[]="2009.12.21"; //写指令 void Send_Com(unsigned char Send_Com) { u16 Temp;//定义短整型变量Temp,由于STM32F103C8的GPIOA恰好有16个IO口。 Delay(0xAFFFF); CLR_RS; Temp=GPIO_ReadOutputData(GPIOA);//读回GPIOA发送寄存器的数据。 Temp&=0xff00;//将GPIOA的高8位保留,低8位清0. Temp|=(u16)Send_Com;//将char型变量Send_Com强制转换成short(短整型),其中高8位由0代替,低8位是Send_Com的值 GPIO_Write(GPIOA,Temp); Delay(100); Set_EN; Delay(100); CLR_EN; } //写数据 void Send_Dat(unsigned char Send_Dat) { u16 Temp;//定义短整型变量Temp,由于STM32F103C8的GPIOA恰好有16个IO口。 Set_RS; Temp=GPIO_ReadOutputData(GPIOA);//读回发送寄存器内的数据 Temp&=0xff00; Temp|=(u16)Send_Dat; GPIO_Write(GPIOA,Temp); Delay(100); Set_EN; Delay(500); CLR_EN; } void init() { CLR_EN; //Delay(0xAFFF); Send_Com(0x38); //置初值// Send_Com(0x0c); Send_Com(0x06); Send_Com(0x80); } void GPIO_Configuration(void) { GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; GPIO_Init(GPIOB,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; GPIO_Init(GPIOA,&GPIO_InitStructure); } void RCC_Configuration(void) { RCC_DeInit(); RCC_HSEConfig(RCC_HSE_ON); HSEStartUpStatus= RCC_WaitForHSEStartUp(); if(HSEStartUpStatus==SUCCESS) { RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); FLASH_SetLatency(FLASH_Latency_2); FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET) { } RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource()!=0x08) { } RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC , ENABLE); } } int main(void) { #ifdef DEBUG debug(); #endif unsigned char num; RCC_Configuration(); GPIO_Configuration(); init(); for(;;) { for(num=0;num<8;num++) { Send_Dat(table[num]); Delay(2000000); } //while(1); //Send_Com(0x01); Delay(20000); Send_Com(0x80+0x40); for(num=0;num<10;num++) { Send_Dat(table1[num]); Delay(2000000); } while(1); } } |
