虽然数值可以从0到359,但唯一的实际选项是60和120度。对我来说,似乎不太可能在“错误”设置下你的电机运行得更好。
s.ptl.05
2016年3月5日星期六,下午10:10
ST Motor Workbench - 放置电角度
你能描述一下如何设置''Placement electrical angle''。 ST Motor Workbench的默认值为300度。
我有一个8极电机,120度间隔霍尔传感器。根据我在网上找到的信息,我将此设置为60度,并且我在该设置下也获得了最大的扭矩。我把它解释为不同大厅状态之间的角度差异。
我问这个问题是因为''Placement electrical angle''的值可以是0到359度,我想知道什么时候改变了。
根据我的理解,如果使用120度间隔的霍尔传感器,则60度以外的值不应该正常工作......但是,ST Motor Workbench中的选项一定不是这种情况。
问候,
萨加尔
以上来自于谷歌翻译
以下为原文
Although the numerical value can go from 0 to 359, the only real options are 60 and 120 degrees. To me it seems unlikely that your motor runs better with the ''wrong'' setting.
s.ptl.05
Saturday, March 05, 2016 10:10 PM
ST Motor Workbench - Placement electrical angle
Could you describe how to set ''Placement electrical angle''. The default value in ST Motor Workbench is 300 degrees.
I have an 8-pole motor with 120 degree spaced hall sensors. I have this set to 60 degrees based off information I found online and I get the most torque at that setting as well. I'm interpreting it as the angle difference between different hall states.
I ask the question because the value of ''Placement electrical angle'' can be from 0 to 359 degrees and I'd like to understand when that changes.
From my understanding a value other than 60 degrees shouldn't work properly if using 120 degree spaced hall sensors...but that must not be the case hence the option in ST Motor Workbench.
Regards,
Sagar
s.ptl.05
问候,
萨加尔
以上来自于谷歌翻译
以下为原文
s.ptl.05
Regards,
Sagar
