Qualcomm技术william hill官网
李艺银
7年用户 1091经验值
高通Vuforia SDK 2.8的Extended Tracking功能
高通Vuforia SDK 2.8已经正式推出了,此次SDK更新的亮点:增加Extended Tracking功能,即使目标离开视野仍能继续进行图像识别。使用Java API使开发更简单。采用基于云的内容存储。
Extended Tracking,简称 扩展追踪,在目标丢失的状态,通过扩展追踪,通过对周围环境的采集,让你在丢失识别卡片一段时间,仍然可以体验AR;这样,对于一些AR大场景的游戏,以及一些AR创意都可以更好的呈现;
目前,Extended Tracking可以支持很多中识别模式;
These targets support Extended Tracking:
Image Targets
Multi-Targets
Cylinders
User-Defined Targets
Cloud Recognition
提示: Text and Frame Markers do not support Extended Tracking.
具体,可以去一下链接去看;链接如下https://developer.vuforia.com/resources/dev-guide/extended-tracking
本人也测试过,得出以下结论,仅供参考:
(1)一定得在识别之后,然后,丢失识别之时,Extended Tracking才会发挥出其真正作用;
(2)ImageTargetBehaviour.cs中,代码不可见了,不知道为什么;
(3)在显示内容过于大的时候,从识别到丢失识别会卡一下;
Native API
这段代码显示了更新可追踪基类定义,以及用于更新的API
startExtendedTracking() and stopExtendedTracking which control this feature:
class
QCAR_API Trackable : private
NonCopyable
Starts extended tracking for this Trackable
This function will return true if extended tracking was
successfully started for this Trackable (or already started)
and false otherwise.
    virtual
bool startExtendedTracking() = 0;
Stops extended tracking for the Trackable
successfully stopped for this Trackable (or already stopped)
    virtual
bool stopExtendedTracking() = 0;
    virtual
~Trackable()  {}
再次请注意,这仅适用于子类以下Trackables:ImageTargets,MultiTargets,Cylinders,User Defined Targets和Cloud Recognition。文本和Framemarkers不支持扩展跟踪。
接下来,TrackableResult类已更新,这样的的getStatus()API,现在返回一个EXTENDED_TRACKED的状态,如果是可跟踪拿出来看时,扩展跟踪已启用。如果可追踪是鉴于它返回跟踪的状态。
最后,Tracker class已经更新到启用和禁用持久性扩展跟踪和重置扩展跟踪,如前面所述。
class
QCAR_API Tracker : private
NonCopyable
Enables/disables persistent extended tracking
In persistent extended tracking mode, the environment map will only
ever be reset when the developer calls resetExtendedTracking().
This function will return true if persistent extended tracking
was set successfully (or was already set to the specified value)
    virtual
bool persistExtendedTracking(bool on) = 0;
Resets environment map for extended tracking
Environment map can only be reset by the developer if persistent
extended tracking is enabled.
This function will return true if environment map was reset
successfully and false otherwise.
    virtual
bool resetExtendedTracking() = 0;
