工程资源中心
李雪
7年用户 949经验值
[电源设计]
用于Vcore的48V至1V/40A单级转换器包括BOM及层图
描述
            The PMP4497 is a GaN-based reference design solution for the Vcore such as FPGA, ASIC applications. With high integration and low switching loss, the GaN module LMG5200 enables a high efficiency single stage from 48V to 1.0V solution to replace the traditional 2-stage solution. This design shows the  (...)
主要特色
  • LMG5200 GaN FET module
  • Single stage Half-Bridge Current-Doubler topology
  • Extra high Efficiency up to 89.9% with full load @48Vin
  • DCAP+ Controlling with the TPS53632G
  • Compact size: 45mm*26mm*11mm
