托比亚斯和西蒙你好,
此M60卡是此DL380 Gen9服务器中唯一的额外卡。
如果我们测试几次重新启动,那么在XenServer 7.2的启动阶段,风扇每次都会在同一时刻旋转到100%。
所以我的结论是:它与温度无关,只有一些“逻辑”认为风扇应该达到100%的速度(噪音是恼人的副作用)。
在该服务器中有2x 1400W电源,两者都运行“冗余”,目前仅提供409W。
因此,这些M60板的电源是正确的。
M60卡由惠普提供,nvidia-smi正在识别主板,目前我已经拥有了第一台使用M60卡的Win10工作站,所以一切运行正常,只有风扇速度和生成
噪音是一个问题。
如果没有其他想法,我会在HPE支持上记录一张票。
谢谢和问候,
克里斯
以上来自于谷歌翻译
以下为原文
Hello Tobias and Simon,
This M60-card is the only extra card in this DL380 Gen9 server. And the fans are spinning up to 100% during the startup-phase of the XenServer 7.2 each time at exact the same moment if we test a few reboots. So my conclusion : it has nothing to do with temperature, only with some 'logic' that is thinking the fans should go to 100% speed (with the noise as annoying side effect).
In that server there are 2x 1400W power supply's, both running 'redundant' and at the moment only delivering 409W. So the power supply's are correct for these M60-boards.
The M60-cards are delivered by HP, and the nvidia-smi is recognizing the board, and at the moment I already have my first Win10-station using the M60-card, so everything is running fine, only the fan speed and the generated noise is an issue.
If there are no other thoughts, I will log a ticket at HPE Support for this.
Thanks and greetings,
Chris
托比亚斯和西蒙你好,
因此,这些M60板的电源是正确的。
噪音是一个问题。
谢谢和问候,
克里斯
以上来自于谷歌翻译
以下为原文
Chris
