ST意法半导体
王莹
7年用户 165经验值
为什么Motor Profiler不支持STEVAL-SPIN3202/3201板?
以来
STSPIN32F0 / A已包含F0内核,
并且船上有st-link。
为什么电机探测器不支持这两块板?
#spin32f0
以上来自于谷歌翻译
以下为原文
Since
STSPIN32F0/A already contains a F0 core,
and there is st-link on board.
Why motor profiler does not support these two boards?
#spin32f0
回帖(4)
丁峙昌
2018-10-10 10:54:54
我看到一个帖子,他们说F0只是不够强大,无法运行探查器。只有F3及以上
以上来自于谷歌翻译
以下为原文
I saw a post they say F0 just not powerful enough to run the profiler. Only F3 and up
王莹
2018-10-10 11:11:32
感谢回复,Diandi!
这也是我的想法,
如果您在STSW-SPIN3201中编译示例项目,
闪光灯和内存几乎100%被利用!
以上来自于谷歌翻译
以下为原文
Thanks for reply, Diandi!
That's what I think too,
for if you compile the sample project in STSW-SPIN3201,
the flash and ram are almost 100% utilized!
丁峙昌
2018-10-10 11:16:32
我遇到了同样的问题。一开始我尝试生成一个trueStudio项目,使用'-o3'优化编译。代码大小小于32k,但它没有(我在指出TrueStudio中不支持F0的hal库之后读了一篇文章。我不知道这是不是问题。而且我也试过LL驱动程序没有运气)所以我切换到keil(你可以获得f0的免费许可),现在编译的代码大小约为23k,只启用了霍尔传感器。
我在这里有关于代码大小的帖子:
https://community.st.com/0D50X00009XkW99SAF
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
I encountered the same problem. At beginning I tried to generate a trueStudio project, compiled with '-o3' optimization on. The code size is less than 32k but it didn't(I read a post after pointing out that the hal library for F0 is not supported in TrueStudio yet. I don't know if that's the problem. And I also tried LL driver with no luck) So I switched to keil(you can get free license for f0), now the compiled code size is about 23k with only hall sensor enabled.
I have a post about code size here:
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
萧蔼晨
2018-10-10 11:28:46
亲爱的大家,
你是对的,F0不够强大,无法进行分析。主要原因是没有FPU是强制性的。
问候
塞德里克
以上来自于谷歌翻译
以下为原文
Dear all,
You are right, F0 is not powerful enough to do profiling. The main reason is that there is no FPU which is mandatory.
Regards
Cedric
