Hello
william hill官网
,建立一个利用MTCH6102手势识别的项目-该设备有两个触摸表面(圆圈,直径20mm,3x3轮廓)。是否需要两个芯片,用于每个触摸表面,或者有一种方式将两个触摸表面连接到一个芯片上,并利用片上手势识别。关于MTCH6102?重要的是要知道哪一个触摸面识别手势。提前感谢:PS:伟大的william hill官网
,帮助我很大的开始。
以上来自于百度翻译
以下为原文
Hello forum,
building a project that u
tilizes MTCH6102 gesture recognition - the device has two touch surfaces (circles, diameter 20mm each, 3x3 outline).
Do I need two chips, for each touch surface, or there is a way to connect two touch surfaces to one chip AND utilize the on-chip gesture recognition of MTCH6102? It is important to tell which touchsurface recognised the gesture.
Thank you in advance :)
ps: great forum, helped me greatly to get started.
