Cypress技术william hill官网
彭丞峥
7年用户 159经验值
如何将XTAL频率信息存储到非易失性存储器中
你好,
CYW92070XV3EVAL评估板硬件用户指南称,CYW20706或CYW20707上的PIN BTXXTALYSTRAPGL0和BTXXTALYSTRAPGL1可以用来选择XTAL频率,并且它还表示在BTXXTALYSTRAP0SP0和BTXXTALYSTRAPHL1上的1的值使得CYW20706/07能够读取来自非易失性存储器。
问题:
你能帮助我理解如何将XTAL频率信息存储到非易失性存储器中吗?XTAL信息何时读取并应用?XTAL FRQ是如何使用的?
这将是非常有用的,如果你可以直接在WSDE SDK 5的地方,这已经完成了。
谢谢您,
普拉文库马
以上来自于百度翻译
     以下为原文
  Hi,
CYW92070xV3_EVAL evaluation board hardware user guide says that pin BT_XTAL_STRAP_0 and BT_XTAL_STRAP_1 on CYW20706 or CYW20707 can be used to select XTAL frequency and it also says that the value of 1 on both BT_XTAL_STRAP_0 and BT_XTAL_STRAP_1 makes the CYW20706/07 to read the frequency from Non volatile memory.
Question :
Can you help me understand how to store XTAL frequency information into Non volatile memory ? When is this XTAL info read and applied ? How the XTAL freq used ?
It would be very helpful if you can direct to place in WICED SDK 5.0 where this is already being done.
Thank you,
Pravinkumar
回帖(9)
孙世珍
2018-11-15 16:14:40
此配置是作为构建过程的一部分为您完成的。它由你使用的制作目标控制:
SNIP.BT.A2DPX-SIK-CYW920706WCDEVALFRY= 40MHz构建
在早期的SDK中,有完全独立的平台文件:
A2DPIXNK-BCM920706YP44040MHZ
A2DPIXNK-BCM920706P42424MHz构建
雅各伯
以上来自于百度翻译
     以下为原文
  This configuration is done for you as part of the build process. It is controlled by the make target you use:
snip.bt.a2dp_sink-CYW920706WCDEVAL FREQ=40Mhz build
In earlier SDKs, there are separate platform files entirely:
a2dp_sink-BCM920706_P49_40MHz build
a2dp_sink-BCM920706_P49_24MHz build
Jacob
彭丞峥
2018-11-15 16:32:32
得到了,我正在使用的SDK有单独的平台文件。
我使用的是CYW20706,我想提供18MHz晶体,请帮助我理解IOWH如何将这个配置写入非易失性存储器中,顺便说一下,我不使用与EVE板相同的闪存。
请与我分享一个完全解释这个过程的医生。
谢谢你
以上来自于百度翻译
     以下为原文
  Got it, the SDK I am using has got separate platform files.
I am using CYW20706 and I would like to provide 18MHz crystall, Please help me understand ihow this configuration is written into non volatile memory and by the way I am not using the same flash memory as it is in eval board.
Please share with me a doc that explains this procedure completely.
Thank you
孙世珍
2018-11-15 16:41:32
请与我分享一个完全解释这个过程的医生。
我们只支持20MHz,24MHz和40MHz晶体为20706。
雅各伯
以上来自于百度翻译
     以下为原文
  We only support 20MHz, 24MHz, and 40MHz crystals for 20706.
Jacob
彭丞峥
2018-11-15 16:52:35
雅各伯
但是,20706数据表表示,它可以支持固件配置(从串行闪存或EEPROM读取)支持20MHz、24MHz和40MHz以外的频率。
——Pravin
以上来自于百度翻译
     以下为原文
  But, the 20706 data sheet says that it can support frequencies other than 20MHz, 24MHz, and 40MHz by firmware configuration (reading from serial flash or EEPROM).
--Pravin
