我从大师会议上获得了ICD4,直到今天早上才开始工作。我被提示在通知窗口中注册我的ICD4,然后它就停止了连接到目标。有什么想法吗?ICD 4输出窗口?与APP、版本、01.02.01BooE版本、01.00 .00
FPGA版本、01.00 .00脚本版本、0.02.01Bug编号脚本、E310ED01F6目标电压检测目标设备PIC32 MZ2048 EFG064找到。设备ID修订号0xA1序列号:NUM0=398FE711NUM1= 43AED880擦除…下面的内存区域将被编程:程序存储器:起始地址=0x1d00亿,结束地址=0x1D0d9FFFFITCH内存启动编程/验证完成ununHal停…脚本停止失败,状态类型=RunScript,脚本名称=HALT,STAuto= 0x601。无法运行目标设备。
以上来自于百度翻译
以下为原文
I picked up a ICD4 from the Masters conference and it's been working great un
til this morning. I was prompted to register my ICD4 in the notifications window and then it just stopped connecting to the target. Any ideas as to what is wrong?
ICD 4 output window?
Connected to App, version, 01.02.01
Boot version, 01.00.00
FPGA version, 01.00.00
Scripts version, 00.02.01
Build number scripts, e310ed01f6
Target voltage detected
Target device PIC32MZ2048EFG064 found.
Device Id Revision = 0xA1
Serial Number:
Num0 = 398fe711
Num1 = 43aed880
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x1d000000, end address = 0x1d0d9fff
configuration memory
boot config memory
Programming/Verify complete
Running
Halting...
Script Halt failed with status Type = runScript, Script name = Halt, Status = 0x601
Unable to run the target device.
