ST意法半导体
傅利
8年用户 204经验值
STVP/STM8S-Discovery崩溃了Windows
STVP / STM8S-Discovery崩溃了Windows
以上来自于谷歌翻译
以下为原文
STVP / STM8S-Discovery crashes Windows
回帖(16)
傅利
2019-4-16 10:51:22
我希望我做的事情很愚蠢,但是如果我试图让STVP与我的STM8S-Discovery板通信它会导致Windows崩溃 - 崩溃报告说这是由于驱动程序故障。
我正在运行XP Pro SP3和STVP 3.1.3
我安装了STVP,然后将Discovery插入.STM8S-Discovery用户手册(UM0817)说:''当连接USB时,ST-Link的驱动程序会自动安装。''
Windows使用通用Microsoft驱动程序将设备配置为USB大容量存储设备,这不是我所期望的。虽然它确实包含3个STM网页的Internet快捷方式,但是显然有人希望它有时可以作为磁盘访问。
STM8S-Discovery运行Discover程序OK(当您触摸打击垫时,闪烁的绿色LED会改变速度),但是威廉希尔官方网站 板的ST-Link部分没有任何活动迹象。
如果我尝试从设备读取任何内容 - 特别是UM0834第4部分中的选项字节:''开发和调试STM8S-DISCOVERY应用程序代码'' - Windows立即崩溃。
有什么建议么?
[此消息由以下人员编辑:smh于2009年11月30日01:12]
以上来自于谷歌翻译
以下为原文
I hope I'm doing something stupid, but if I try to get STVP to communicate with my STM8S-Discovery board it crashes Windows - the crash report says it's due to a driver fault.
I'm running XP Pro SP3 and STVP 3.1.3
I installed STVP then plugged the Discovery in. The STM8S-Discovery User Manual (UM0817) says: ''The driver for ST-Link is installed automatically when the USB is connected.''
Windows configures the device as a USB mass-storage device using a generic Microsoft driver, which is not what I expected. Though it does contain 3 Internet shortcuts to STM web pages, so someone evidently expected it to be accessed as a disk sometimes.
The STM8S-Discovery runs the Discover program OK (flashing green LED changes speed when you touch the pad), but there's no sign of activity on the ST-Link part of the board.
If I try to read anything from the device - in particular the option bytes as per section 4 of UM0834: ''Developing and debugging your STM8S-DISCOVERY application code'' - Windows crashes immediately.
Any suggestions?
[ This message was edited by: smh on 30-11-2009 01:12 ]
傅利
2019-4-16 11:02:58
也许我可以诱惑某人回答一些直接的问题:
有没有人用STVP成功运行STM8s-Discovery?
如果是,那么哪个驱动程序与设备相关联? (您可以在Windows设备管理器中检查设备的属性)。
你是如何安装该驱动程序的?
我现在已经没有想法,因为我认为很有前途的小评估板甚至不够重,不足以成为一个好的镇纸!
以上来自于谷歌翻译
以下为原文
Perhaps I can tempt someone to reply to some direct questions:
  • Has anyone got an STM8s-Discovery running successfully with STVP?
  • If so, what driver is associated with the device? (You can check the properties of the device in Windows Device Manager).
  • How did you install that driver?
    I'm out of ideas at the moment and as things stand my promising little evaluation board is not even heavy enough to be a good paperweight!
陈玉筠
2019-4-16 11:11:38
很安静的板。我刚拿到了威廉希尔官方网站 板,我设法编译了这个例子。据我所知,唯一的驱动程序是通用USB磁盘驱动程序。我没有安装任何东西。可能还有其他内容,但它未在Windows中注册。这来自远离专家的人,在linux或Mac上做这件事会更舒服。 BTW这是通过Mac上的VMWare在WinXP上运行的。
当它上传并与威廉希尔官方网站 板通信时,LED像坚果一样闪烁,所以我知道它正在工作。
以上来自于谷歌翻译
以下为原文
Pretty quiet board. I just got the board and I managed to compile the example. As far as I see the only driver is the generic USB disk driver. I did not install anything. There may be something else but it isn't registered in Windows. This comes from someone who is far from an expert and would be more comfortable doing this on linux or mac. BTW this is running on WinXP via VMWare on a Mac.
When it uploaded and communicated with the board the LED flashed like nuts so I know it was working.
傅利
2019-4-16 11:28:39
感谢您的反馈。
我只是尝试了另一台计算机并且它正常通信 - 正如你所说的那样闪烁红色LED。
所以现在我必须弄清楚为什么我的主机崩溃如此可怕:两台机器都是XP Pro SP3 / AMD,据我所知,它们都使用相同的USB存储设备和磁盘驱动器驱动程序版本。
以上来自于谷歌翻译
以下为原文
Thanks for the feedback.
I just tried on a different computer and it communicates OK - flashing red LED as you say.
So now I have to figure out why my main machine crashes so horribly: both machines are XP Pro SP3 / AMD and as far as I can see both are using the same driver versions for USB Storage Device and Disk Drive.
