是德科技
云甫太
8年用户 184经验值
使用labview来操作DMM设备卡住
嗨,我正在使用labview来操作DMM(使用“Vise写入”和“Vise读取”VI)。除了一件事之外,所有功能都很好。当我将设备输入“周期”或“频率”测量模式时
然后选择“ACDCI”(FSOURSE ACDCI),设备卡住,大约一分钟后自动重置。我做错了什么,或者它是设备?谢谢你,leon。
以上来自于谷歌翻译
     以下为原文
  Hi,
i'm using labview to operate the DMM (with the "Vise write" and "Vise read" VI's).
all is working well, besides one thing.
when I enter the device into "Period" or "frequency" measurment mode and then select "ACDCI" (FSOURSE ACDCI),
the device gets stuck and after about a minute resets automaticly.
Am i doing something wrong, or is it the device?
thank you,
leon.
回帖(6)
杨梅
2019-5-27 14:15:31
你介意附上你的labview程序,这样我就可以看了。
如果您不方便在此发布,可以通过私信发送给我。
以上来自于谷歌翻译
     以下为原文
  Do you mind attaching your labview program so I can take a look.  If your not comfortable posting it here you can send it in a private message to me.
杨梅
2019-5-27 14:29:03
这是我创建的labview文件。如果你试图读取频率读数,请确保你有一个信号连接到3458A,否则你可能会超时.3458A_FREQ_ACDCI_FORUM.zip
以上来自于谷歌翻译
     以下为原文
  Here is the labview file I created.
Make sure you have a signal connected to the 3458A if you are trying to take a frequency reading otherwise you will probably get a timeout.3458A_FREQ_ACDCI_FORUM.zip
附件
云甫太
2019-5-27 14:35:59
嗨,仍然没有工作。事情是所有其他FSOURCE功能都工作。但是在FSOURCE ACDCI上,DMM显示“TRAP#-1 7518”并自动重启,错误“16384”(系统错误)。可能是硬件问题?
谢谢你的帮助.leon
以上来自于谷歌翻译
     以下为原文
  Hi, still not working.
The thing is that all other FSOURCE functions work.
But on FSOURCE ACDCI the DMM displays "TRAP #-1 7518" and restarts automaticly with the error "16384" (system error).
Could it be hardware problems?
Thank you for your help.
leon
杨梅
2019-5-27 14:53:30
你好Leon,你有一个连接到AC / DC电流端子的带电信号。
当没有连接信号时,我得到同样的错误,但当我从函数发生器连接信号时,测量成功完成。确保您的信号连接到电流端子,而不是电压端子。
以上来自于谷歌翻译
     以下为原文
  Hi Leon,
Do you have a live signal connected to the AC/DC current terminals.  I was getting this same error when no signal was connected, but when I connected my signal from a function generator the measurement completed successfully.
Make sure your signal is connected to the current terminals, not the voltage terminals.
