综合技术
赵敏
7年用户 1082经验值
阿波罗F7的MPU9250例程移植到STM32F103R8T6上后编译出错
这是编译出现的错误:
DZJZDZJZ.axf: Error: L6366E: compass_vec_cal.o attributes are not compatible with the provided attributes .
Object compass_vec_cal.o contains Build Attributes that are incompatible with the provided attributes.
    Tag_CPU_arch = ARM v7E-M (=13)
DZJZDZJZ.axf: Error: L6366E: fast_no_motion.o attributes are not compatible with the provided attributes .
Object fast_no_motion.o contains Build Attributes that are incompatible with the provided attributes.
DZJZDZJZ.axf: Error: L6366E: fusion_9axis.o attributes are not compatible with the provided attributes .
Object fusion_9axis.o contains Build Attributes that are incompatible with the provided attributes.
DZJZDZJZ.axf: Error: L6366E: gyro_tc.o attributes are not compatible with the provided attributes .
Object gyro_tc.o contains Build Attributes that are incompatible with the provided attributes.
DZJZDZJZ.axf: Error: L6366E: mag_disturb.o attributes are not compatible with the provided attributes .
Object mag_disturb.o contains Build Attributes that are incompatible with the provided attributes.
DZJZDZJZ.axf: Error: L6366E: quaternion_supervisor.o attributes are not compatible with the provided attributes .
Object quaternion_supervisor.o contains Build Attributes that are incompatible with the provided attributes.
DZJZDZJZ.axf: Error: L6366E: accel_auto_cal.o attributes are not compatible with the provided attributes .
Object accel_auto_cal.o contains Build Attributes that are incompatible with the provided attributes.
Not enough information to list image symbols.
Not enough information to list the image map.
哪位大神遇到过这样的情况?求指教!!!
回帖(4)
史乃原
2019-7-9 10:49:04
参考下别人的:https://blog.csdn.net/wearlee/article/details/70215234
李允麒
2019-7-9 11:04:54
F7例程里面的libmpllib.lib这个库文件是不是针对F7生成的,F1的用不了?
陈涛
2019-7-9 11:11:04
谢谢原子哥,已找到问题!
李峰
2019-10-22 11:48:22
请问怎么解决的,共享一下呗
