嵌入式学习小组
石建军
7年用户 168经验值
分享一个不错的Maxim MAX9888立体声音频CODEC解决方案
本文介绍了MAX9888主要特性,功能方框图,典型应用威廉希尔官方网站 图以及MAX9888评估板主要特性,方框图,威廉希尔官方网站 图和材料清单。
回帖(1)
刘晓英
2021-6-1 14:33:46
  Maxim 公司的MAX9888是采用FlexSound技术的全特性立体声音频CODEC,立体声DAC的DR为100dB(8kHz fS 96kHz),立体声ADC的DR为91dB(8kHz fS 96kHz),立体声低EMI D类放大器950mW/每路,集成了DirectDrive耳机放大器和差分接收放大器,其高性能和低功耗适合用在手持设备。本文介绍了MAX9888主要特性,功能方框图,典型应用威廉希尔官方网站 图以及MAX9888评估板主要特性,方框图,威廉希尔官方网站 图和材料清单。 The MAX9888 is a full-featured audio CODEC whose high performance and low power consumption make it ideal for portable applications.
  Class D speaker amplifiers provide efficient amplification for two speakers. Low radiated emissions enable completely filterless operation. Integrated bypass switches optionally connect an external amplifier to the transducer when the Class D amplifiers are disabled.
  DirectDrive® headphone amplifiers provide a true ground-referenced output, eliminating the need for large DC-blocking capacitors. 1.8V headphone opera-tion ensures low power consumption. The device also includes a differential receiver amplifier.
  Three differential analog microphone inputs are available as well as support for two PDM digital microphones. Integrated switches allow microphone signals to be routed out to external devices. Two flexible single-ended or differential line inputs may be connected to an FM radio or other sources.
  Integrated FlexSoundK technology improves loud-speaker performance by optimizing the signal level and frequency response while limiting the maximum distor-tion and power at the output to prevent speaker damage. Automatic gain control (AGC) and a noise gate optimize the signal level of microphone input signals to make best use of the ADC dynamic range.
  The device is fully specified over the -40NC to +85NC extended temperature range.
  MAX9888主要特性:
  100dB DR Stereo DAC (8kHz 《 fS 《 96kHz)
  91dB DR Stereo ADC (8kHz 《 fS 《 96kHz)
  Stereo Low EMI Class D Amplifiers 950mW/Channel (8I, VSPKVDD_ = 4.2V)
  Stereo DirectDrive Headphone Amplifiers
  Differential Receiver Amplifier
  2 Stereo Single-Ended/Mono Differential Line Inputs
  3 Differential Microphone Inputs
  FlexSound Technology 5-Band Parametric EQ Automatic Level Control (ALC) Excursion Limiter Speaker Power Limiter Speaker Distortion Limiter Microphone Automatic Gain Control and Noise Gate
  Dual I2S/PCM/TDM Digital Audio Interfaces
  Asynchronous Digital Mixing
  Supports Master Clock Frequencies from 10MHz to 60MHz
  RF Immune Analog Inputs and Outputs
  Extensive Click-and-Pop Reduction Circuitry
  I2C Control Interface
  63 WLP Package (3.80mm x 3.30mm, 0.4mm Pitch)
  图1.MAX9888功能框图
  图2.MAX9888典型应用威廉希尔官方网站 图:采用模拟麦克风输入和旁路开关
  图3.MAX9888典型应用威廉希尔官方网站 图:采用数字麦克风输入和接收放大器
  MAX9888评估板
  The MAX9888 evaluation kit (EV kit) is a fully assembled and tested circuit board that evaluates the MAX9888 audio codec. The MAX9888 is an integrated audio codec including microphone amplifiers, line amplifiers, an earpiece amplifier, stereo Class D amplifiers, stereo DirectDriveM headphone amplifiers, and digital signal processing. The EV kit also includes Windows XPM-,Windows VistaM-, and WindowsM 7-compatible software that provides a simple graphical user interface (GUI) for exercising the features of the device.
  The EV kit provides access to all analog and digital inputs/outputs on the device. To enable easy connection to a wide range of audio sources, audio devices are included to convert both USB data and S/PDIF data to I2S.
  The EV kit integrates a MAXQ2000 microcontroller to enable I2C communication with devices on the EV kit.
  The EV kit software, running on a Windows PC, communicates with the EV kit over a standard USB port. The EV kit software provides an intuitive interface to exercise the
  functions of the device.
  The EV kit comes with a MAX9888EWY+ installed.
  MAX9888评估板主要特性:
  2.8V to 5.5V Single-Supply Operation
  Proven Audio PCB Layout
  On-Board USB-to-I2C Interface
  On-Board USB-to-I2S Converter
  On-Board S/PDIF Transceiver
  On-Board Clock Source
  On-Board Digital Microphone
  Evaluates the MAX9888EWY+ in a 3.8mm x
  3.3mm, 63-Bump WLP Package
  Windows XP-, Windows Vista-, and Windows
  7-Compatible Software
  Fully Assembled and Tested
  图4.MAX9888评估板方框图
  图5.MAX9888评估板威廉希尔官方网站 图(1)
  图6.MAX9888评估板威廉希尔官方网站 图(2)
  图7.MAX9888评估板威廉希尔官方网站 图(3)
  图8.MAX9888评估板威廉希尔官方网站 图(4)
  图9.MAX9888评估板威廉希尔官方网站 图(5)
  MAX9888评估板材料清单(BOM):
  图10.MAX9888评估板元件布局图
  详情请见:
  MAX9888[1].pdf(10.25 MB)2012-4-13 12:58 上传
  -1
  和
  MAX9888EVKIT[1].pdf(2.51 MB)2012-4-13 12:59 上传
  -1
