最新git sdk
我在自己添加节点,实现rk355 控制rk628d,也看了你们william hill官网
其他相关文档。麻烦请支持下;
从今年的2月份就有人发william hill官网
后,说后续会支持rk628d,现在时12月中旬了,我刚前二天发帖还是说后续会支持.....
我现在就自己调试一个hdmiin 转mipi就可以了。
报错如下
rk3566_firefly_aiojd4:/ $ dmesg |grep 'rk628'
[ 1.020168] rk628 2-0050: failed to access register: -6
[ 0.971936] rk628 2-0050: failed to request reset GPIO: -16
[ 0.971968] rk628: probe of 2-0050 failed with error -16
dts配置如下: 我用的是i2c2,从模式&i2c2 {
status = "okay";
// clock-frequency = <400000>;//时钟
clock-frequency = <2400000>;//时钟
// pinctrl-0 = <&i2c2m0_xfer>;
// hym8563: hym8563@51 {
// status = "okay";
// compatible = "haoyu,hym8563";
// reg = <0x51>;
// #clock-cells = <0>;
// rtc-irq-gpio = <&gpio0 RK_PD4 IRQ_TYPE_EDGE_FALLING>;
// clock-frequency = <32768>;
// //clock-output-names = "xin32k";
// /* rtc_int is not connected */
rk628: rk628@50 {//如需使用rk628传输mipi信号要使能
compatible = "rockchip,rk628";//驱动match用
reg = <0x50>;//地址
interrupt-parent = <&gpio3>;//中断parent
interrupts = <RK_PD5 IRQ_TYPE_LEVEL_LOW>;//中断引脚和极性
reset-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_LOW>;//复位gpio
status = "okay";
#include "rk628.dtsi"
&rk628_combtxphy {//如需使用rk628传输mipi信号要使能
status = "okay";
&rk628_combrxphy {//如需使用rk628传输mipi信号要使能
status = "okay";
// 图像接收链路dts配置
&rk628_csi {//如需使用rk628传输mipi信号要使能
status = "okay";
//plugin-det-gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
power-gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>;//配置电源gpio
rockchip,camera-module-index = <0>;//配置camera模块
rockchip,camera-module-facing = "back";//配置camera模块
rockchip,camera-module-name = "RK628-CSI";//配置camera模块
rockchip,camera-module-lens-name = "NC";//配置camera模块
port {
hdmiin_out0: endpoint {//配置endpoint
// remote-endpoint = <&hdmi2mipi_in>;//远端endpoint名 //zcp先关闭
data-lanes = <1 2 3 4>;//数据线数
at /sys/kernel/debug/clk/clk_summary |grep gpio <
dbclk_gpio 0 0 0 24000000 0 0 50000
dbclk_gpio4 0 0 0 24000000 0 0 50000
dbclk_gpio3 0 0 0 24000000 0 0 50000
dbclk_gpio2 0 0 0 24000000 0 0 50000
dbclk_gpio1 0 0 0 24000000 0 0 50000
pclk_gpio4 1 1 0 99000000 0 0 50000
pclk_gpio3 1 1 0 99000000 0 0 50000
pclk_gpio2 1 1 0 99000000 0 0 50000
pclk_gpio1 1 1 0 99000000 0 0 50000
dbclk_gpio0 0 0 0 24000000 0 0 50000
pclk_gpio0 1 1 0 100000000 0 0 50000
