WIZnet技术专区
jf_73422347
3年用户 3经验值
[技术问题讨论]
使用stm32,通过spi的dma 收发,运行多次读写以后w5500发送正常,接收卡死,高人帮忙看看
使用STM32,通过spi的dma 收发,运行多次读写以后w5500发送正常,接收卡死,高人帮忙看看
void PY_W5500_Read(uint8_t ah, uint8_t al, uint8_t ctl, uint8_t* data, uint16_t length)
    PY_W5500_CS_EN
    PY_SPIDMA__Status = 1;
    PY_CMD_Seg[0] = ah;
    PY_CMD_Seg[1] = al;
    PY_CMD_Seg[2] = ctl & 0xfb;//hwy----三个函数主要是控制字区别
    //HAL_SPI_Transmit_DMA(&hspi2, PY_CMD_Seg, 3);
                HAL_SPI_Transmit(&hspi2, PY_CMD_Seg, 3,4096);
    //while(PY_SPIDMA__Status == 1) ;
    //DWT_DELAY_uS(1);
    //HAL_SPI_Receive_DMA(&hspi2, data, length);
                HAL_StatusTypeDef st = HAL_SPI_Receive(&hspi2, data, length,4096);//注意超时参数
                if(st == HAL_tiMEOUT)
                        PY_SPIDMA__Status = 2;
//                uint8_t timeout_temp = 0;
//    while(PY_SPIDMA__Status == 1)// ;//卡卡卡
//                        DWT_DELAY_uS(1);
//                        timeout_temp++;
//                        if(timeout_temp > 200)
//                                break;
    PY_W5500_CS_DEN
    DWT_DELAY_uS(1);
//---------发送缓冲区地址高位,地址低位,控制字,数据,长度
void PY_W5500_Send(uint8_t ah, uint8_t al, uint8_t ctl, uint8_t* data, uint16_t length)
    PY_W5500_CS_EN
    PY_CMD_Seg[0] = ah;
    PY_CMD_Seg[1] = al;
    PY_CMD_Seg[2] = ctl | 0x04;//hwy----三个函数主要是控制字区别
    //while(PY_SPIDMA__Status == 1) ;//发送命令码要等发送完
    //HAL_SPI_Transmit_DMA(&hspi2, data, length);
                HAL_SPI_Transmit(&hspi2, data, length,4096);
    //while(PY_SPIDMA__Status == 1) ;//发送内容完全可以不等
    PY_W5500_CS_DEN
                DWT_DELAY_uS(1);
