MSP430技术william hill官网
季昱
6年用户 20经验值
MSP430FR5994 使用库函数 定时器触发AD问题请教
我用的芯片是MSP430FR5994,使用的是库函数
我AD用软件触发没有问题,能进入中断
但是我用定时器触发就不行了
定时器单独跑也没有问题,PWM信号 IO脚也出来了
但是AD 用定时器触发就是不行
void Ad_init(void)
ADC12_B_initParam param1 = {0};
ADC12_B_configureMemoryParam param = {0};
GPIO_setAsPeripheralModuleFunctionOutputPin(
    GPIO_PORT_P3,
    GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3,
    GPIO_TERNARY_MODULE_FUNCTION
int main(void)
WDTCTL = WDTPW | WDTHOLD; // stop watchdog timer
PMM_unlockLPM5();
CS_init();
IO_Init();
Timer_Init();
Ad_init();
while(1)
// ADC12_B_startConversion(ADC12_B_BASE, ADC12_B_MEMORY_0, ADC12_B_SINGLECHANNEL);
//LPM0, ADC12_A_ISR will force exit
        __bis_SR_register(LPM0_bits + GIE);
        //for Debugger
        __no_operation();
// __delay_cycles(5000);
GPIO_setOutputLowOnPin(GPIO_PORT_P2,GPIO_PIN0);
    GPIO_setOutputHighOnPin(GPIO_PORT_P2,GPIO_PIN0);
// GPIO_setOutputHighOnPin(GPIO_PORT_P4,GPIO_PIN0);
return 0;
//Setup Timer B0
TBCCR0 = 0xfffe;
TBCCR1 = 0x8000;
TBCCTL1 = OUTMOD_3; // CCR1 set/reset mode
TBEX0 = TBIDEX_0; //CLK/8 divide
TBCTL = TBSSEL_2+MC_1+TBCLR ; // SMCLK, Up-Mode
// Setup ADC12
   ADC12CTL0 = ADC12ON+ADC12MSC;   // Turn on ADC12, extend sampling time
                                               // to avoid overflow of results
   ADC12CTL1 = ADC12SHS_3+ADC12CONSEQ_3;       // Use sampling timer, repeated sequence
   ADC12MCTL0 = ADC12INCH_3;                  // ref+=AVcc, channel = A0
   __data20_write_long((uintptr_t) &DMA0SA,(uintptr_t) &ADC12MEM0); // Source block address
   __data20_write_long((uintptr_t) &DMA0DA,(uintptr_t) &g_usAdcData[0]);
   // Setup DMA COMMON
   DMACTL0 = DMA0TSEL_24 ;      // ADC12IFGx triggered
   DMACTL4 = DMARMWDIS;                      // Read-modify-write disable
   // Setup DMA0
   DMA0CTL &= ~DMAIFG;
   DMA0SZ = 64;        // DMA0 size = 100
   ADC12CTL0 |= ADC12ENC;                    // Enable conversions
   DMA0CTL = DMAIE+DMADT_4+DMAEN+DMADSTINCR_3;     // Rpt single tranfer, Destination address is incremented.
// param1.sampleHoldSignalSourceSelect=ADC12_B_SAMPLEHOLDSOURCE_SC;
param1.sampleHoldSignalSourceSelect=ADC12_B_SAMPLEHOLDSOURCE_1;
param1.clockSourceSelect=ADC12_B_CLOCKSOURCE_MCLK;
param1.clockSourceDivider=ADC12_B_CLOCKDIVIDER_1;
param1.clockSourcePredivider=ADC12_B_CLOCKPREDIVIDER__1;
param1.internalChannelMap=ADC12_B_NOINTCH;
ADC12_B_init(ADC12_B_BASE,&param1);
ADC12_B_setupSamplingTimer(ADC12_B_BASE,
ADC12_B_CYCLEHOLD_64_CYCLES,
ADC12_B_CYCLEHOLD_4_CYCLES,
ADC12_B_MULTIPLESAMPLESDISABLE);
ADC12_B_MULTIPLESAMPLESENABLE);
param.memoryBufferControlIndex = ADC12_B_MEMORY_0;
param.inputSourceSelect = ADC12_B_INPUT_A12;
param.refVoltageSourceSelect = ADC12_B_VREFPOS_AVCC_VREFNEG_VSS;
param.endOfSequence = ADC12_B_NOTENDOFSEQUENCE;
param.windowComparatorSelect = ADC12_B_WINDOW_COMPARATOR_DISABLE;
param.differentialModeSelect = ADC12_B_DIFFERENTIAL_MODE_DISABLE;
ADC12_B_configureMemory(ADC12_B_BASE ,&param);
    ADC12_B_clearInterrupt(ADC12_B_BASE,ADC12IFG0,0);
        ADC12_B_enableInterrupt(ADC12_B_BASE, ADC12IE0,0,0);
ADC12_B_enable(ADC12_B_BASE);
// * main.c
void Timer_Init(void)
Timer_A_initUpModeParam htim = {0};
htim.clockSource = TIMER_A_CLOCKSOURCE_SMCLK; //时钟源选为SMCLK = 1048576 HZ
// htim.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_2; //32分频 32768
htim.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_32; //32分频 32768
htim.timerPeriod = TIMER_PERIOD - 1; //计数值设为16374(32768/2=16374),定时0.5s
htim.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_ENABLE; //使能TALE中断
// htim.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_DISABLE; //使能TALE中断
htim.captureCompareInterruptEnable_CCR0_CCIE = TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE;
// htim.timerClear = TIMER_A_DO_CLEAR; //把定时器的定时计数器,分频计数器的计数值清零
htim.timerClear = TIMER_A_SKIP_CLEAR; //把定时器的定时计数器,分频计数器的计数值清零
htim.startTimer = false; //初始化后立即启动定时器
Timer_A_initUpMode(TIMER_A0_BASE, &htim);
Timer_A_initContinuousModeParam initContParam = {0};
Timer_A_initUpModeParam Param={0};
initContParam.clockSource = TIMER_A_CLOCKSOURCE_SMCLK;
initContParam.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_1;
initContParam.timerInterruptEnable_TAIE=TIMER_A_TAIE_INTERRUPT_ENABLE;
initContParam.timerClear=TIMER_A_DO_CLEAR;
initContParam.startTimer = true;
Timer_A_initContinuousMode(TIMER_A1_BASE, &initContParam);
//Start timer in continuous mode sourced by SMCLK
initContParam.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_DISABLE;
initContParam.timerClear = TIMER_A_DO_CLEAR;
initContParam.startTimer = false;
//Initiaze compare mode
Timer_A_clearCaptureCompareInterrupt(TIMER_A1_BASE,
    TIMER_A_CAPTURECOMPARE_REGISTER_0
Timer_A_initCompareModeParam initCompParam = {0};
initCompParam.compareRegister = TIMER_A_CAPTURECOMPARE_REGISTER_1;
initCompParam.compareInterruptEnable = TIMER_A_CAPTURECOMPARE_INTERRUPT_ENABLE;
// initCompParam.compareInterruptEnable = TIMER_A_CAPTURECOMPARE_INTERRUPT_DISABLE;
initCompParam.compareOutputMode = TIMER_A_OUTPUTMODE_TOGGLE;
// initCompParam.compareOutputMode = TIMER_A_OUTPUTMODE_SET_RESET;
initCompParam.compareValue = 10;
Timer_A_initCompareMode(TIMER_A0_BASE, &initCompParam);
Timer_A_outputPWMParam htim1 = {0};
//P1.2复用输出
htim1.clockSource = TIMER_A_CLOCKSOURCE_SMCLK;
//分频系数设为32  32768HZ
htim1.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_32;
//装载值设为8192 - 1  ,周期为0.25s
htim1.timerPeriod = TIMER_PERIOD - 1;
//P1.2 对应 TA0.1 故设为TIMER_A_CAPTURECOMPARE_REGISTER_1   定时器为0
htim1.compareRegister = TIMER_A_CAPTURECOMPARE_REGISTER_1;
//选择复位置位模式
htim1.compareOutputMode = TIMER_A_OUTPUTMODE_RESET_SET;
//设置占空比,为5%
htim1.dutyCycle = TIMER_PERIOD / 2 ;
//P1.2 对应 TA0.1 为TIMER_A0_BASE
Timer_A_outputPWM(TIMER_A0_BASE, &htim1);
// Timer_A_startCounter( TIMER_A0_BASE, TIMER_A_UP_MODE );
TIME 我实验了 COMPARE PWM 各种方式,而且P0.1 信号也出来了,但是AD的中断就是进不去
请问哪位遇到过这个问题,多谢了
回帖(2)
季昱
2024-3-19 14:48:33
// * main.c
int main(void)
        PMM_unlockLPM5();
        CS_init();
        IO_Init();
        Timer_Init();
    Ad_init();
        while(1)
                //for Debugger
                __no_operation();
        return 0;
// * main.c
void CS_init()
    // Set PJ.4 and PJ.5 as Secondary Module Function Input, LFXT.
     /* Initializes Clock System DCO = 8MHz */
    CS_setDCOFreq(CS_DCORSEL_0, CS_DCOFSEL_3);
    CS_initClockSignal(CS_MCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_2);
    CS_initClockSignal(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_2 );
    CS_initClockSignal(CS_ACLK, CS_VLOCLK_SELECT, CS_CLOCK_DIVIDER_1);
// * main.c
void Ad_init(void)
        GPIO_PORT_P3,
    ADC12_B_init(ADC12_B_BASE,¶m1);
    ADC12_B_configureMemory(ADC12_B_BASE ,¶m);
// * main.c
// * main.c
void IO_Init(void)
        GPIO_setAsOutputPin(GPIO_PORT_P1,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
         GPIO_setAsOutputPin(GPIO_PORT_P2,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
        GPIO_setAsOutputPin(GPIO_PORT_P3,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
        GPIO_setAsOutputPin(GPIO_PORT_P4,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
  //      GPIO_setOutputLowOnPin(GPIO_PORT_P1,GPIO_PIN0);
        GPIO_setOutputHighOnPin(GPIO_PORT_P1,GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
        GPIO_setOutputHighOnPin(GPIO_PORT_P2,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
        GPIO_setOutputHighOnPin(GPIO_PORT_P3,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
        GPIO_setOutputHighOnPin(GPIO_PORT_P4,GPIO_PIN0+GPIO_PIN1+GPIO_PIN2+GPIO_PIN3+GPIO_PIN4+GPIO_PIN5+GPIO_PIN6+GPIO_PIN7);
  //      GPIO_setAsInputPin(GPIO_PORT_P1,GPIO_PIN0);
        GPIO_setAsPeripheralModuleFunctionOutputPin(GPIO_PORT_P1,GPIO_PIN0,GPIO_PRIMARY_MODULE_FUNCTION);
刚才代码贴错了
季昱
2024-3-19 15:07:17
// * main.c
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=ADC12_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(ADC12_VECTOR)))
#endif
void ADC12_ISR(void)
  switch(__even_in_range(ADC12IV,12))
    case  0: break;                         // Vector  0:  No interrupt
    case  2: break;                         // Vector  2:  ADC12BMEMx Overflow
    case  4: break;                         // Vector  4:  Conversion time overflow
    case  6: break;                         // Vector  6:  ADC12BHI
    case  8: break;                         // Vector  8:  ADC12BLO
    case 10: break;                         // Vector 10:  ADC12BIN
    case 12:
        // Vector 12:  ADC12BMEM0 Interrupt
        g_usAdcData[0]=   ADC12_B_getResults(ADC12_B_BASE, ADC12_B_MEMORY_0);
          __bic_SR_register_on_exit(LPM0_bits); // Exit active CPU
      break;                                // Clear CPUOFF bit from 0(SR)
    case 14: break;                         // Vector 14:  ADC12BMEM1
    case 16: break;                         // Vector 16:  ADC12BMEM2
    case 18: break;                         // Vector 18:  ADC12BMEM3
    case 20: break;                         // Vector 20:  ADC12BMEM4
    case 22: break;                         // Vector 22:  ADC12BMEM5
    case 24: break;                         // Vector 24:  ADC12BMEM6
    case 26: break;                         // Vector 26:  ADC12BMEM7
    case 28: break;                         // Vector 28:  ADC12BMEM8
    case 30: break;                         // Vector 30:  ADC12BMEM9
    case 32: break;                         // Vector 32:  ADC12BMEM10
    case 34: break;                         // Vector 34:  ADC12BMEM11
    case 36: break;                         // Vector 36:  ADC12BMEM12
    case 38: break;                         // Vector 38:  ADC12BMEM13
    case 40: break;                         // Vector 40:  ADC12BMEM14
    case 42: break;                         // Vector 42:  ADC12BMEM15
    case 44: break;                         // Vector 44:  ADC12BMEM16
    case 46: break;                         // Vector 46:  ADC12BMEM17
    case 48: break;                         // Vector 48:  ADC12BMEM18
    case 50: break;                         // Vector 50:  ADC12BMEM19
    case 52: break;                         // Vector 52:  ADC12BMEM20
    case 54: break;                         // Vector 54:  ADC12BMEM21
    case 56: break;                         // Vector 56:  ADC12BMEM22
    case 58: break;                         // Vector 58:  ADC12BMEM23
    case 60: break;                         // Vector 60:  ADC12BMEM24
    case 62: break;                         // Vector 62:  ADC12BMEM25
    case 64: break;                         // Vector 64:  ADC12BMEM26
    case 66: break;                         // Vector 66:  ADC12BMEM27
    case 68: break;                         // Vector 68:  ADC12BMEM28
    case 70: break;                         // Vector 70:  ADC12BMEM29
    case 72: break;                         // Vector 72:  ADC12BMEM30
    case 74: break;                         // Vector 74:  ADC12BMEM31
    case 76: break;                         // Vector 76:  ADC12BRDY
    default: break;
//This is the TIMER1_A3 interrupt vector service routine.
#pragma vector=TIMER0_A1_VECTOR
__interrupt
__attribute__((interrupt(TIMER0_A1_VECTOR)))
#endif
void TIMER0_A1_ISR (void)
    switch(TA0IV)
         case TA0IV_NONE:
             break;
         case TA0IV_TACCR1:
             GPIO_toggleOutputOnPin(
                 GPIO_PORT_P2,
                 GPIO_PIN1
             break;
         case TA0IV_TACCR2:
             break;
         case TA0IV_5:
             break;
         case TA0IV_6:
             break;
         case TA0IV_TAIFG:
                //Toggle P1.0
                    GPIO_PORT_P2,
                    GPIO_PIN1
             break;
         default:
             break;
