在生成工程时,出现如下错误:
Opening project creator from C:/Users/XXX/ModusToolbox/tools_3.2/project-creator/project-creator.exe
Project Creator Status:
Project: Hello_World_1
Loca
tion: D:/Infineon/03/Hello_World_1
Status: failed
[1]: [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/device-configurator-cli/device-configurator-cli-20240626.170103.333-14676.log"
[2]: [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/device-configurator/device-configurator-cli.exe --build D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus --readonly"
[3]: [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/hardware-config-server/hardware-config-server-20240626.170104.542-5352.log"
[4]: [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/hardware-config-server/hardware-config-server.exe --config D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus"
[5]: [INFO] Library paths: "D:/Infineon/03/mtb_shared/mtb-pdl-cat1/release-v3.10.1/props.json;C:/Users/XXX/.modustoolbox/global/device-db/release-v4.16.0/props.json"
[6]: Error loading file. The design file was locked by another host. The file is locked by "闂佽法鍠愰弸濠氬箯閻戣姤鏅搁柡鍌樺�栫�氳瀵� [D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus]
[7]: Failed to load 'D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus'.
[8]: Failed to export the "Hello_World_1" application to Eclipse IDE for ModusToolbox闁筹拷
Unable to import the project: Hello_World_1. Try "Import Existing Application" from the quick-panel. If issues persist, retry project creator.
No new/valid projects found.
