ARM技术william hill官网
风清雾起
12年用户 526经验值
擅长:嵌入式技术
[资料]
TQ2440裸奔程序:串口UART的PC机按键测试程序
  TQ2440是由广州天嵌计算机科技有限公司精心打造的一款开发板。以稳定的性能,过硬的质量,丰富的扩展接口,优质的售后服务和技术支持,赢得众多企业的青睐和支持。
  // NAME: main.c
  // DESC: TQ2440串口UART测试程序
  /* 头文件包含 */
  #include "def.h"
  #include "option.h"
  #include "2440addr.h"
  #include
  #include
  #include
  #include
  #include
  static volatile int uart_port = 0;
  void uart_init(int pclk,int buad,int ch)
  //UART初始化:端口使能、功能设定、波特率、设置数据格式
  rGPHCON = (rGPHCON & ~(0xfff<<4)) | (0xaaa<<4);//端口RX[0:2]、TX[0:2]功能
  rGPHUP = rGPHUP | (0x7<<1); //端口GPH[1:3]禁止上拉
  rUFCON0 = 0x0; //禁止FIFO
  rUFCON1 = 0x0; //禁止FIFO
  rUFCON2 = 0x0; //禁止FIFO
  rUMCON0 = 0x0; //禁止AFC
  rUMCON1 = 0x0; //禁止AFC
  //Normal:No parity:One stop:8-bits 中断响应 UART clock: PCLK
  rULCON0 = (rULCON0 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
  rUCON0 = (rUCON0 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
  rUBRDIV0 = ((int)(pclk/16./buad+0.5)-1);
  rULCON1 = (rULCON1 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
  rUCON1 = (rUCON1 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
  rUBRDIV1 = ((int)(pclk/16./buad+0.5)-1);
  rULCON2 = (rULCON2 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
  rUCON2 = (rUCON2 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
  rUBRDIV2 = ((int)(pclk/16./buad+0.5)-1);
  uart_port = ch; //设置串口端口号
  // 串口发送函数
  void uart_send_byte(int data)
  if(0 == uart_port)
  if(data == 'n')
  while(!(rUTRSTAT0 & 0x2));
  rUTXH0 = 'n';
  rUTXH0 = data;
  else if(1 == uart_port)
  if(data == 'n')
  while(!(rUTRSTAT1 & 0x2));
  rUTXH1 = 'n';
  rUTXH1 = data;
  else if(2 == uart_port)
  if(data == 'n')
  while(!(rUTRSTAT2 & 0x2));
  rUTXH2 = 'n';
  rUTXH2 = data;
  void uart_send_string(char *string)
  while(*string)
  uart_send_byte(*string++);
  void uart_printf(char *fmt,...)
  va_list ap;
  char string[256];
  va_start(ap,fmt);
  vsprintf(string,fmt,ap);
  uart_send_string(string);
  va_end(ap);
  // 串口接收函数
  void uart_tx_empty(void)
  if(0 == uart_port)
  while(!(rUTRSTAT0 & 0x4));//等待Tx为空
  if(1 == uart_port)
  while(!(rUTRSTAT1 & 0x4));//等待Tx为空
  if(2 == uart_port)
  while(!(rUTRSTAT2 & 0x4));//等待Tx为空
  char uart_get_ch(void)
  if(0 == uart_port)
  while(!(rUTRSTAT0 & 0x1));//等待Rx被读
  return rURXH0; //读缓存寄存器
  while(!(rUTRSTAT1 & 0x1));//等待Rx被读
  return rURXH1; //读缓存寄存器
  while(!(rUTRSTAT2 & 0x1));//等待Rx被读
  return rURXH2; //读缓存寄存器
  return 0;
  char uart_get_key(void)
  if(0 == uart_port)
  if(rUTRSTAT0 & 0x1) //Rx被读
  else
  return 0;
  if(1 == uart_port)
  if(rUTRSTAT1 & 0x1) //Rx被读
  else
  return 0;
  if(2 == uart_port)
  if(rUTRSTAT2 & 0x1) //Rx被读
  else
  return 0;
  return 0;
  void uart_get_string(char *string)
  char *string1 = string;
  char c = 0;
  while((c = uart_get_ch())!='r')
  if(c == 'b')
  if((int)string1 < (int)string)
  uart_printf("bb");
  string--;
  else
  *string++ = c;
  uart_send_byte(c);
  *string = '�';
  uart_send_byte('n');
  int uart_get_intnum(void)
  char str[30];
  char *string = str;
  int base = 10;
  int minus = 0;
  int result = 0;
  int last_index;
  int i;
  uart_get_string(string);
  if(string[0] == '-')
  minus = 1;
  string++;
  if(string[0] == '0' && (string[1] == 'x' || string[1] == 'X'))
  base = 16;
  string = string + 2;
  last_index = strlen(string)-1;
  if(last_index < 0)
  return -1;
  if(string[last_index] == 'h' || string[last_index] == 'H')
  base = 16;
  string[last_index] = 0;
  last_index--;
  if(base == 10)
  //atoi将字符串转换为整型值
  result = atoi(string);
  result = minus ? (-1*result) : result;
  else
  for(i=0;i<=last_index;i++)
  //判断字符是否为英文字母,当为英文字母a-z或A-Z时,返回非零值,否则返回零。
  if(isalpha(string))
  //isupper 判断字符是否为大写英文字母,当c为大写英文字母,返回非零值,否则返回零。
  if(isupper(string))
  result = (result<<4) + string-'A'+10;
  else
  result = (result<<4) + string-'a'+10;
  else
  result = (result<<4) + string-'0'+10;
  return result;
  int uart_get_intnum_gj(void)
  char string[16];
  char *p_string = string;
  char c;
  int i = 0;
  int data = 0;
  while((c = uart_get_ch()) != 'r')
  if(c == 'b')
  p_string--;
  else
  *p_string++ = c;
  //uart_send_byte(c);
  *p_string = '�';
  i=0;
  while(string != '�')
  data = data*10;
  if(string<'0' || string>'9')
  return -1;
  data = data +(string-'0');
  i++;
  return data;
  void Main(void)
  uart_init(50000000,115200,0);
  while(1)
  if('-' == uart_get_ch())
  uart_printf("+n");
  if('+' == uart_get_key())
  uart_printf("-n");
  感谢晨旭晚霞的支持!
  供货情况:
  天嵌科技提供专业嵌入式板卡和行业解决方案。如有需要,可以联系天嵌科技的销售人员。
  销售电话:020-38219416 38373101
  技术支持:020-38219416转807 820
  网址:http://www.embedsky.com
回帖(9)
sally_cheng
2016-3-11 15:35:23
已学习,谢谢楼主!
lzh8
2016-3-11 20:14:19
有些地方看不懂,我还是联系天嵌的大神。
adeechan36
2016-3-13 22:52:44
教程挺多的,适合学习!
2016-3-14 13:51:29
引用: adeechan36 发表于 2016-3-13 22:52
教程挺多的,适合学习!
是的,我也这么认为,一直都是用天嵌的板子。
2016-3-14 13:51:57
感谢楼主分享!
张晓然
2016-3-14 16:10:58
看来2440的支持还是蛮多的嘛,可以考虑入手了哦~
楼主多多分享点吧~
想飞的猫星人
2016-3-16 10:12:01
挺好用的,谢谢楼主
风清雾起
2016-3-16 10:47:20
引用: lzh8 发表于 2016-3-11 20:14
有些地方看不懂,我还是联系天嵌的大神。
可以,多种技术支持方式:电话、邮件、扣扣、旺旺、william hill官网 等等
风清雾起
2016-3-16 10:49:40
楼主多多分享点吧~
请继续关注我们吧,不定期更新技术文章,希望对你们有用
