Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.44.26
Firmware type..............Enhanced Midrange
Programmer to target power is enabled - VDD = 4.875000 volts.
Target device PIC18F47K40 found.
Device ID Revision = a003
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1ffff
configuration memory
program memory
Address: 0 Expected Value: ef0d Received Value: 0
Failed to program device
Programming...
program memory
