规格书spnu517中是这么写的
12.2.1 Counter Operation
Each counter block consists of the following (see Figure 12-2):
• One 32-bit prescale counter (RTIUC0 or RTIUC1)
• One 32-bit free running counter (RTIFRC0 or RTIFRC1)
The RTIUC0/1 is driven by the RTICLK and counts up until the compare value in the compare up counter
register (RTICPUC0 or RTICPUC1) is reached. When the compare matches, RTIFRC0/1 is incremented
and RTIUC0/1 is reset to 0. If RTIFRC0/1 overflows, an interrupt is generated to the vectored interrupt
manager (VIM).
我的意思是,RTIUCPUC0设置一个比较的值,让RTIUC0从0增加,当增加到等于RTIUCPUC0设置的值时(根据RTI的时钟源,使RTIUC0从0增加到RTIUCPUC0的值时间为10mS),此时,RTIFRC0为10mS间隔的次数,RTIUC0又会复位到零,再计数。而RTIFRC0的值不就是10mS的间隔次数么?
规格书spnu517中是这么写的
manager (VIM).
