TIwilliam hill官网
刘飞
7年用户 265经验值
DM6446 H264编译问题,出现以下问题,怎么解决?
dm6446_h264enc_02_02_00_02_production目下将工程导入CCS3.3,编译出现以下问题,怎么解决?
[Linking...] "D:CCStudio_v3.3C6000cgtoolsbincl6x" -@"Debug.lkf"
>> warning: creating output section $build.attributes without SECTIONS
            specification
>>   error: relocation overflow occurred at address 0x00006a6c in section
            '.text:_H264VENC_TI_alloc' of input file 'h264venc_ti_plink.o64P
            (D:/CCStudio_v3.3/dvsdk_1_01_00_15/c64x_h264enc_production/dm6446_h264enc_02_02_00_02_production/packages/ti/sdo/codecs/h264enc/app/Client/Build/../../../Lib/h264venc_ti.l64P)'.  The 29-bit PC-relative displacement 524064758 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction.
>>   error: relocation overflow occurred at address 0x00006138 in section
            '.text:_H264VENC_TI_free' of input file 'h264venc_ti_plink.o64P
            (D:/CCStudio_v3.3/dvsdk_1_01_00_15/c64x_h264enc_production/dm6446_h264enc_02_02_00_02_production/packages/ti/sdo/codecs/h264enc/app/Client/Build/../../../Lib/h264venc_ti.l64P)'.  The 29-bit PC-relative displacement 524067062 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction.
>> Compilation failure
Build Complete,
  3 Errors, 1 Warnings, 0 Remarks.
谢谢!
回帖(1)
刘飞
2018-5-28 15:45:06
根据相关FAQ,编译器版本要求6.1,切换之后问题就解决了
