之前的所有学习都是从SD卡启动uboot,今天开始折腾从nand启动uboot,于是在之前的基础上继续更改代码,实现该功能。
结果见图
还是设置从SD启动,使用SD卡的uboot,进行烧录,把uboot烧录到nand,完成后,重新上电或reset一下,结果如图
代码需要的更改如下
void copy_bl2_to_ram(void)
** ch: 通道
** ***: 起始块
** bs: 块大小
** dst: 目的地
** i: 是否初始化
#define CopySDMMCtoMem(ch, ***, bs, dst, i)
(((u8(*)(int, u32, unsigned short, u32*, u8))
(*((u32 *)0xD0037F98)))(ch, ***, bs, dst, i))
#define MP0_1CON (*(volatile u32 *)0xE02002E0)
#define MP0_3CON (*(volatile u32 *)0xE0200320)
#define MP0_6CON (*(volatile u32 *)0xE0200380)
#define NF8_ReadPage_Adv(a,b,c) (((int(*)(u32, u32, u8*))(*((u32 *)0xD0037F90)))(a,b,c))
u32 bl2Size = 250 * 1024; // 250K
u32 OM = *(volatile u32 *)(0xE0000004); // OM Register
OM &= 0x1F; // 取低5位
if (OM == 0x2) // NAND 2 KB, 5cycle 8-bit ECC
u32 cfg = 0;
struct s5pv210_nand *nand_reg = (struct s5pv210_nand *)(struct s5pv210_nand *)samsung_get_base_nand();
/* initialize hardware */
/* HCLK_PSYS=133MHz(7.5ns) */
cfg = (0x1 << 23) | /* Disable 1-bit and 4-bit ECC */
/* 下面3个时间参数稍微比计算出的值大些(我这里依次加1),否则读写不稳定 */
(0x3 << 12) | /* 7.5ns * 2 > 12ns tALS tCLS */
(0x2 << 8) | /* (1+1) * 7.5ns > 12ns (tWP) */
(0x1 << 4) | /* (0+1) * 7.5 > 5ns (tCLH/tALH) */
(0x0 << 3) | /* SLC NAND Flash */
(0x0 << 2) | /* 2KBytes/Page */
(0x1 << 1); /* 5 address cycle */
writel(cfg, &nand_reg->NFConf);
writel((0x1 << 1) | (0x1 << 0), &nand_reg->nfcont);
/* Disable chip select and Enable NAND Flash Controller */
/* Config GPIO */
MP0_1CON &= ~(0xFFFF << 8);
MP0_1CON |= (0x3333 << 8);
MP0_3CON = 0x22222222;
MP0_6CON = 0x22222222;
int i = 0;
int pages = bl2Size / 2048; // 多少页
int offset = 0x4000 / 2048; // u-boot.bin在NAND中的偏移地址(页地址)
u8 *p = (u8 *)CONFIG_SYS_SDRAM_BASE;
for (; i < pages; i++, p += 2048, offset += 1)
NF8_ReadPage_Adv(offset / 64, offset % 64, p);
else if (OM == 0xC) // SD/MMC
u32 V210_SDMMC_BASE = *(volatile u32 *)(0xD0037488); // V210_SDMMC_BASE
u8 ch = 0;
/* 参考S5PV210手册7.9.1 SD/MMC REGISTER MAP */
if (V210_SDMMC_BASE == 0xEB000000) // 通道0
ch = 0;
else if (V210_SDMMC_BASE == 0xEB200000) // 通道2
ch = 2;
CopySDMMCtoMem(ch, 32, bl2Size / 512, (u32 *)CONFIG_SYS_SDRAM_BASE, 0);
其他的就不多说了
