各位好:
参考官网的ADE7878示例代码,然后发现SPI读任何寄存器都全是0XFFFFFFFF,感觉应该是没通讯上,但是又不知道问题在哪,有哪位用过的可以帮忙看下吗? 附上示例代码, 诚心请教! 有好心人可以加我的QQ:79444528或者微信solo_wen,求指导. 已经弄了两周了. 下面是我的一些详细信息:
1.硬件原理图:
已经量VREF(C28)两端电压为1.19V
2.软件:
SPI配置:
void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direc
tion = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_HIGH;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64; // 80M/64
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
然后CLKPolarity HIGH,LOW都试过, CLKPhase 1,2EDGE也都试过,都没用.
ADE78XX_SPI.C
Author : CAC (China Applications Support Team)
Date : October 2012
File : ADE7878_SPI.h
Hardware : ADE7878, ADuC7060
Description : Test with ADE7878
Config ADE7878 to read phase A current rms, voltage rms, energy, period, in linecycle mode
#include "ADE78xx_spi.h"
#include "extern.h"
//extern unsigned char szTxData[7];
unsigned char DummyRd;
SPI_HandleTypeDef* ADE_hspi = &hspi1;
uint8_t SPI_comm(uint8_t s_byte);
** Abstract:
** short delay
** Parameters:
** none
** Returns:
** none
void SPIDelay(void)
int i;
for(i=0; i<20; i++);
** Abstract:
** write 4 bytes to ADE7878
** Parameters:
** unsigned int address: register address
** long int sendtemp : configuration value
** Returns:
** none
void SPIWrite4Bytes(unsigned int address , long int sendtemp)
char i;
CLR_PIN00();
szTxData[0] = 0x00;
szTxData[1] = (char)(address>>8);
szTxData[2] = (char)(address);
szTxData[3] = (char)(sendtemp>>24);
szTxData[4] = (char)(sendtemp>>16);
szTxData[5] = (char)(sendtemp>>8);
szTxData[6] = (char)(sendtemp);
for(i=0;i<7;i++)
SPI_comm(szTxData
SPIDelay();
SET_PIN00();
** Abstract:
** write 2 bytes to ADE7878
** Parameters:
** Returns:
** none
void SPIWrite2Bytes(unsigned int address , int sendtemp)
char i;
CLR_PIN00();
szTxData[0] = 0x00;
szTxData[3] = (char)(sendtemp>>8);
szTxData[4] = (char)(sendtemp);
for(i=0;i<5;i++)
SPI_comm(szTxData);
SPIDelay();
SET_PIN00();
** Abstract:
** write 1 byte to ADE7878
** Parameters:
** Returns:
** none
void SPIWrite1Byte(unsigned int address , char sendtemp)
char i;
CLR_PIN00();
szTxData[0] = 0x00;
szTxData[3] = sendtemp;
for(i=0;i<4;i++)
SPI_comm(szTxData);
SPIDelay();
SET_PIN00();
** Abstract:
** read 4 bytes from ADE7878
** Parameters:
** Returns:
** readout : read value
long int SPIRead4Bytes(unsigned int address)
long int readout;
char spireadbuf[4];
char i;
CLR_PIN00();
szTxData[0] = 0x01;
for(i=0;i<3;i++)
SPI_comm(szTxData);
SPIDelay();
// SPICON |= BIT12; // Flush Rx FIFO
// SPICON &= ~BIT12;
// DummyRd = SPI_comm(0x00);
for(i=0;i<4;i++)
SPIDelay();
spireadbuf = SPI_comm(0x00);
readout = (spireadbuf[0]<<24)+(spireadbuf[1]<<16)+(spireadbuf[2]<<8)+spireadbuf[3];
SET_PIN00();
return(readout);
** Abstract:
** read 2 bytes from ADE7878
** Parameters:
** Returns:
int SPIRead2Bytes(unsigned int address)
int readout;
char i;
char spireadbuf[2];
CLR_PIN00();
szTxData[0] = 0x01;
for(i=0;i<3;i++)
SPI_comm(szTxData);
SPIDelay();
for(i=0;i<2;i++)
// SPITX = 0x00;
SPIDelay();
readout = (spireadbuf[0]<<8)+spireadbuf[1];
SET_PIN00();
return(readout);
** Abstract:
** read 1 byte from ADE7878
** Parameters:
** Returns:
char SPIRead1Byte(unsigned int address)
char readout;
char i;
CLR_PIN00();
szTxData[0] = 0x01;
for(i=0;i<3;i++)
SPI_comm(szTxData);
SPIDelay();
// SPITX = 0x00;
SPIDelay();
readout = SPI_comm(0x00);
SET_PIN00();
return(readout);
uint8_t ret = 0;
HAL_SPI_TransmitReceive(ADE_hspi, &s_byte, &ret, 1, 0xfff);
return ret;
以上基本参考的示例程序, 只把发送和接收这里改成了我的库函数.
ADE7878.C就是示例程序一模一样了.
然后我在Main里面函数这样调用的.
MX_SPI1_Init();
ADE7878Reset();
ADE7878SPICfg();
然后最后执行读写寄存器,如下图:
2018-8-7 08:47:34
找个逻辑分析仪或四通道的示波器把SPI通讯波形量一下,上图。
2018-8-7 09:02:23
您好,我现在在调试ADE7880 的SPI通信,读取寄存器时得到的值为0XFF。通过示波器抓取ADE7880的 SPI引脚,发现ADE7880的SPI输出一直是高电平2.7V,所以,导致MCU读到的数据都是0XFF。
因此,我单独拿ADE7880 模块(不与MCU相连),当VDD(或REST)输入3.3V时,ADE7880 SPI引脚也是为高。
请问,ADE7880的SPI引脚,默认都是高电平吗?
2018-8-7 09:27:12
ADE7878外部的晶振起振没?SPI接口电平测了吗?还有芯片有没有更换过?是不是芯片坏了?
你都做了那些实验?
你都做了那些实验?
