嗨,Ted,
我只是测试,根据医生所说的步骤。对你的问题:
1。在步骤5中,它表示“点击文件并保存*。cysmif示例中的根文件夹,“但我要拯救我的文件到文件夹是什么?我的。cywrk.csw文件是在C:柏 psoc6_t4所以这是我要保存到的文件夹吗?而且,在这一步中,如果我去文件& gt;保存,只保存在没有我的地方说,如果我去文件& gt;另存为,我必须指定文件名,这个问题我不太清楚
你可以保存文件到你的项目的根文件夹,把ce220823为例: smif_memory_write_and_read_operation01.cydsn smif_memory_write_and_read_operation01…
2。这也是模棱两可的选项>;配置对话框是如何被保存在哪里你能澄清吗?
--Q1中提到的文件夹。
三。是否需要将生成的文件添加到项目中?如果是,我在下面的步骤中没有指定
-不需要手动添加它们。
请试试,让我知道如果它仍然不工作。
以上来自于百度翻译
以下为原文
Hi Ted,
I just tested it according to the steps mentioned in that doc. To your questions:
1. In step 5, it says "Click File and save *.cysmif in the example root folder" but what is the folder that I should be saving my files into? My .cywrk.csw file is in is in C:CypressPSoC6_T4 so is this the folder I should save into? And, for this step, If I go File > Save, it just saves somewhere without me saying where and, if I go File > Save As, I have to specify the filename so I'm not sure about this
--you can save files into root folder of your project, take CE220823 as example: ...SMIF_Memory_Write_and_Read_Operation01SMIF_Memory_Write_and_Read_Operation01.cydsn
2. It's also ambiguous in the Options > Configurations dialog box as to what's being saved where - can you clarify?
--the same folder mentioned in Q1.
3. Do I need to add the generated files to my project? If so, this is not specified in the steps I'm following
--no need to add them manually.
Please try then and let me know if it still doesn't work.
嗨,Ted,
--Q1中提到的文件夹。
-不需要手动添加它们。
请试试,让我知道如果它仍然不工作。
以上来自于百度翻译
以下为原文
Hi Ted,
