你好,
这取决于其他情况,例如测量设备的物理设置。请注意,LPS25HB是一种气压传感器,因此需要加入某种气垫。您可以尝试将传感器放入一盒密封空气中(为了快速评估,请尝试带密封的塑料食品盒)。
下面的计算只是一个粗略的估计:
压力定义为每面积的力(p = F / A)。力被定义为重量乘以地球的重力常数(cca 9,8
米/秒^ 2
,但是,对于简单的计算,我们可以说10,这意味着F = m * g,对于一个常设的人来说。 F = 80 kg * 10 m / s ^ 2 = 800 N.一英尺的区域(在跑步过程中只有一个被踩到)可能是1 dm ^ 2,这意味着如果你踩到一个内部有大气压力的盒子,用一只脚,你可以增加压力p = F / A = 800 N / 0,01平方公尺= 80 000 Pa。
该传感器的范围仅为25 000 - 125 000 Pa,大气压力为cca 100 000 Pa,因此踩在箱子上会产生大约180 000 Pa,超出范围。
大卫
以上来自于谷歌翻译
以下为原文
Hello,
It depends on other circumstances, for example physical setup of your measurement device. Please note that LPS25HB is an air pressure sensor, so some kind of air 'cushion' needs to be incorporated. You could try putting the sensor into a box of sealed air (for quick evaluation, try a plastic food box with a sealing).
The calculation below is just a rough estimation:
Pressure is defined as force per area (p = F / A). Force is defined as weight multiplied by earth's gravity constant (cca 9,8
m/s^2
, but let's say 10 for simplier calculations), meaning F = m * g, for a standing person ca. F = 80 kg * 10 m/s^2 = 800 N.Area of a foot (only one is being stepped on during a run) could be 1 dm^2, which means if you step on a box with atmospheric pressure inside, with one foot, you could increase the pressure by p = F / A = 800 N / 0,01 m^2 = 80 000 Pa.
The range of this sensor is just 25 000 - 125 000 Pa. and the atmospheric pressure is cca 100 000 Pa, so stepping on the box will give you about 180 000 Pa, which exceeds the range.
David
你好,
下面的计算只是一个粗略的估计:
米/秒^ 2
大卫
以上来自于谷歌翻译
以下为原文
Hello,
m/s^2
David
