嗨,
我需要有关您的测试的更多信息,1。pressureLog_25Hz和2 .car压力日志。
我认为在这两种情况下都没有控制环境。你可否确认?
我会知道两种情况下使用的设置。
它们是一样的吗?
ODR的价值是多少?温度和压力的内部平均值是多少?是否启用了嵌入式过滤?在第一种情况下,如果环境不受控制,为什么你会期望温度变化,而不是压力?
我还需要知道用于测试的电压值是多少。
问候
安东内拉
我和我的同事正在评估LPS25HB并遇到了一些我们不理解的行为。我们现在正试图解决两个问题:
嵌入式温度补偿行为令人困惑。准确性不是应该的.Specifics:
在我们的一个数据记录(pressureLog_25Hz.xlsx)中,我们看到绝对压力跟踪温度。我们预计温度会发生变化,但不是绝对压力。绝对压力以约3hPa / C的速率变化。嵌入式温度补偿不应该处理这个吗?在我们在汽车(汽车压力log.xlsx)中进行的测试中,我们看到温度下降然后增加,但是如果您在数据中绘制趋势线,则压力几乎是恒定的。这次嵌入式温度补偿似乎正在做些什么。我们需要帮助确定传感器为什么表现不同。该部件的数据表声称在20到60℃之间的绝对精度为+/- 0.2 hPa。到目前为止,我们从传感器获取的数据不符合规范。例如,我最近的测试,我们当地的气象站报告的海平面压力为1016.2毫巴。 LPS25HB评估套件告诉我们绝对压力为1026.5毫巴。我们海拔约160,相当于-6毫巴的压力差,因此LPS25HB应报告约1010毫巴。这是16.5毫巴!谢谢您的帮助!
以上来自于谷歌翻译
以下为原文
Hi,
I need further information about your test, 1. pressureLog_25Hz and 2 .car pressure log.
I suppose in both cases the environment was not controlled. Can you confirm?
I would know the settings used in both cases.
Are they the same?
What is the value of ODR? What internal average for temperature and pressure? Was the embedded filtering enabled?In the first case, if the environment is not controlled, why do you expect that temperature changes, but not the pressure?
I need to know what is the value of voltage supply used for your test too.
Regards
Antonella
My colleagues and I are evaluating the LPS25HB and came across some behavior we don't understand. There are two issues we are trying to resolve right now:
- Embedded temperature compensation behavior is confusing.
- Accuracy isn't what it should be.
Specifics:
- In one of our datalogs (pressureLog_25Hz.xlsx) we see absolute pressure tracking with temperature. We expected temperature to change, but not absolute pressure. Absolute pressure is changing at a rate of about 3 hPa/C. Shouldn't the embedded temperature compensation deal with this?
- In a test we did in a car (car pressure log.xlsx), we saw temperature drop and then increase, but the pressure is almost constant if you draw a trend line through the data. It seems like embedded temperature compensation is doing something this time.
- We need help determining why is the sensor acting differently.
- The datasheet for the part claims an absolute accuracy of +/-0.2 hPa between 20 and 60 C. So far, the data we have taken from the sensor does not meet the spec. For example,
- I a recent test, our local weather stations reported a sea level pressure of 1016.2 mbar.
- The LPS25HB evaluation kit is told us the absolute pressure was 1026.5 mbar.
- We are about 160 above sea level, which equates to a pressure difference of -6 mbar, so the LPS25HB should have reported about 1010 mbar. It was off by 16.5 mbar!
Thanks for the help!
嗨,
我会知道两种情况下使用的设置。
它们是一样的吗?
我还需要知道用于测试的电压值是多少。
问候
安东内拉
以上来自于谷歌翻译
以下为原文
Hi,
Are they the same?
Regards
Antonella
Specifics:
