你好,
您可以在不同的条件下找到PSoC 4的电流消耗和来自各个设备数据表的CPU频率。在“设备级规范”部分寻找“DC规范”。下表是PSoC 4100S Plus设备数据表的一个例子。
虽然PSoC 6具有比PSoC 4的有功功率优势,后者具有较低的深睡眠电流。由动力模式和使用各种技术之间的合理转换,你可以很容易地设计与PSoC低功率应用。详情请参阅以下申请须知:
HTTP:/ / www.cypress。COM /文件/应用笔记/ an86233-psoc-4-and-psoc-analog-coprocessor-low-power-modes-and-po…
本应用笔记中还包含一个方便的功率估计电子表格工具。
当做
尼丁
以上来自于百度翻译
以下为原文
Hello,
You can find the PSoC 4 current consumption under different conditions and CPU frequencies from the respective device datasheets. Look for "
DC Specifications" under the section "
Device Level Specifications". Following table is an example from
PSoC 4100S Plus device datasheet.
Although PSoC 6 has an active power advantage over PSoC 4, the latter has lower Deep Sleep currents. By properly switching between the power modes and using a variety of other techniques, you can easily design low power applications with PSoC 4. Please refer to the following application note for details:
http://www.cypress.com/documentation/application-notes/an86233-psoc-4-and-psoc-analog-coprocessor-low-power-modes-and-po…
This application note also contains a handy power estimator spreadsheet tool.
Regards
Nidhin
你好,
当做
尼丁
以上来自于百度翻译
以下为原文
Hello,
Regards
Nidhin
