大家好,我有一台N1996A频谱分析仪,我的目标是通过局域网远程控制这个设备。
我希望能够捕获图像并将这些图像发送到计算机并设置带宽/跨度。
我可以使用puTTY建立连接但是当我尝试在Keysight Connec
tion Expert中“添加LAN设备”时,我无法连接。
所以我有两个问题:是否可以远程捕获图像并将其存储在远程PC上?
如何通过Keysight Connection Expert建立连接?
谢谢阅读!
以上来自于谷歌翻译
以下为原文
Hi all,
I have a N1996A spectrum analyzer and my goal is to remotely control this device via LAN. I want to be able to capture images and send those images to the computer and also set the bandwidth/span. I am able to establish a connection using puTTY but when I attempt to "Add a LAN device" in Keysight Connection Expert, I am unable to connect.
So I have two questions:
Would it be possible to capture images remotely and store them on the remote PC?
How can I establish a connection through Keysight Connection Expert?
Thanks for reading!
