谢谢,这有帮助。但我实际上是在询问磁力计中断,Pin 10,INT_M。我在数据表中找不到任何东西,说它是推拉还是开漏。有效电平(高/低)可以用软件配置,但不能显示输出类型。你知道它是哪个吗?
以上来自于谷歌翻译
以下为原文
Thanks, that helps. But I was actually asking about the magnetometer interrupt, Pin 10, INT_M. I couldn't find anything in the data sheet saying whether it's push-pull or open drain. The active level (high/low) can be configured in software but not, apparently, the output type. Do you know which it is?
以上来自于谷歌翻译
以下为原文
