Cypress技术william hill官网
李永每
7年用户 1448经验值
如果CYUSB3014不使用USB 2.0,如何处理DM/DP引脚
你好,我用CYSUB3014在我们的数据处理单元中用ASB3.0协议把数据传送到PC机。最近,我正在更新这个单元,并认识到DM(引脚A10)和DP(引脚A9)也连接到USB 3端口。我确认,如果这两个引脚是浮动的(没有连接到USB 3端口),我们的数据处理器单元工作良好。
我的问题是如何处理DM(PIN A10)和CYSUB3014的DP(PIN A9),如果没有应用USB 2协议。它们应该是浮动的,上拉到VBUS还是下拉到GND?如果不使用这两个引脚,有什么缺点?
以上来自于百度翻译
     以下为原文
  Hello, I use CYUSB3014 to tranfer data to pc with USB3.0 protocol in our data processor unit. Recently i am updating this unit and realize that the DM (pin A10) and DP (pin A9) are also conntected to the USB 3.0 port. I confirm that if those two pins are floating (without connection to USB 3.0 port), our data processor unit works fine.
My question is how to deal with DM (pin A10) and DP (pin A9) of CYUSB3014 if USB 2.0 protocol is not applied. Should they be floating, pull-up to Vbus or pull-down to GND? What is the disadvantage if those two pins is not used?
回帖(1)
潘沪城
2018-10-8 10:27:13
你好,
如果你不打算使用这两个引脚,你可以让它们浮动。但是,如果你这样做,FX3只是一种枚举方法(UB3.0)。
如果任何条件导致无法枚举USB3.0,则无法在USB2.0中工作。
以上来自于百度翻译
     以下为原文
  Hi,
You could leave these two pins floating if you don't plan to use them. However, if you do that, FX3 will just one way to enumerate(USB3.0).
If any condition which leads to the failure to enumerate as USB3.0, it could not work at USB2.0.
