我不明白你的意思是什么或解决方案是什么,或者一般我该怎么做。
该指令位于lld_spi.c中,不是我编写的,而是来自SPC5Studio的开发人员,我很快就启用了
向导中的spi编译器包含库,它发现错误。
有办法解决它吗?
如果我启用FlexCAN外设而不是我启用例如FlexCAN0,如果我生成并且编译它不可能编译,则会出现同样的问题
分配给它自己'canp-> flexcan-> IFRH.R = canp-> flexcan-> IFRH.R'can_lld.c / prova CAN / components / spc560bxx_low_level_drivers_component_rla / lib / src第95行代码分析问题
以上来自于谷歌翻译
以下为原文
I don't understand what you mean with that or what is the solution or in general what should I do.
That instruction is in the lld_spi.c not written by me but from the developers of SPC5Studio and as soon i enable the
spi in the wizard the compiler includes the library and it founds the error.
there is a way to fix it??
Same problem occurres with CAN if i enable the the FlexCAN peripheral than i enable for instance FlexCAN0 if i generate and than compile it's impossible to compile
Assignment to itself 'canp->flexcan->IFRH.R = canp->flexcan->IFRH.R' can_lld.c /prova CAN/components/spc560bxx_low_level_drivers_component_rla/lib/src line 95 Code Analysis Problem
有办法解决它吗?
以上来自于谷歌翻译
以下为原文
