我想在UART模式(SBC0模式2)和I2C模式(SBC0模式5/6)之间切换。是否有一个命令在运行时切换,还是需要重新编程内部闪存?
如果需要闪存重新编程:
1)闪光灯能经受多少个周期?
2)使用Real/WraveUSER闪存请求(0xe0,0xe1)读取和写入闪存显然是可能的。你能提供一个适合CysB3KIT-03的配置,将SBC0配置从UART模式改为I2C模式吗?
以上来自于百度翻译
以下为原文
I would like to switch between UART mode (SBC0 Mode 2) and I2C modes (SBC0 Mode 5/6). Is there a command to switch at run
time, or does it require reprogramming the internal flash?
If flash reprogramming is required:
1) How many cycles does the flash endure?
2) Reading and writing of the flash is apparently possible using the READ/WRITE_USER_FLASH requests, (0xE0, 0xE1). Can you provide a config suitable for the CyUSB3Kit-003, changing the SBC0 config from UART mode to I2C mode?
