Cypress技术william hill官网
刘刚
7年用户 1015经验值
MBR的I2C速度如何设置
你好
我使用的设备是CY8CMBR31 16-LQXI。
在I2C速度设定上,可选择I2C速度为50、100、400 kHz。
主机的I2C设置频率范围如何从从属设置接受?
以上来自于百度翻译
     以下为原文
  Hello
I use the device wwhich is CY8CMBR3116-LQXI.
It can select I2C speed to 50、100、400 kHz on I2C speed setting.
how range does I2C seting of host acceptable to frequency gap from slave setting?
回帖(1)
李洪洋
2018-10-8 16:33:48
铃木SAN
早上好。
50kHz,100kHz,400 kHz,均为I2C时钟的标准速度。规格中可以发现:https://www.nxp.com/docs/en/user-guide/um10204.pdf I2C标准规格。
因此,在我的心目中,I2C速度选择主机应该50kHz、100kHz,400khz要么。
此外,
如果I2C时钟设置为50kHz,它可以从主机50khz i2c_clk支持;
如果I2C从时钟设置为100kHz,它可以支持50kHz,100khz i2c_clk主机;
如果I2C时钟设置为400kHz,它可以支持50kHz、100kHz,400khz i2c_clk主机。
我希望我理解你的问题和上面的信息可以帮助你。
谢谢,
赖安
以上来自于百度翻译
     以下为原文
  Suzuki-san,
Good morning.
50kHz, 100kHz, 400kHz, all are standard speed of I2C clock. The spec can be found in I2C standard spec: https://www.nxp.com/docs/en/user-guide/UM10204.pdf .
Hence, in my mind, I2C speed options of a host should be 50kHz, 100kHz, 400kHz either.
Besides,
if I2C slave clock is set as 50kHz, it can support 50kHz I2C_Clk from host;
if I2C slave clock is set as 100kHz, it can support 50kHz, 100kHz I2C_Clk from host;
if I2C slave clock is set as 400kHz, it can support 50kHz ,100kHz, 400kHz I2C_Clk from host.
I hope that I understood your questions correctly and above information can help you out.
Thanks,
Ryan
