HelloNoobabooba,感谢您在英特尔有线以太网社区发帖。
环回测试将通过适配器的接收威廉希尔官方网站
和逻辑从适配器发送测试数据包。
由于芯片组不支持测试功能,它可能已经失败。您是否正在运行诊断程序来测试现有问题,您能解释一下这个问题吗?
要进一步解决此问题,请提供System Support Utility日志。
这不会收集任何个人信息。
从上面的链接下载并运行.exe检查“所有内容”然后单击“扫描”扫描完成后单击“下一步”保存日志并将其附加到帖子常见问题解答包含有关此实用程序的其他信息。
如果您有任何疑问,请随时与我们联系。最诚挚的问候,丹尼尔D.
以上来自于谷歌翻译
以下为原文
Hello Noobabooba,
Thank you for posting in Intel Wired Ethernet Communities. The loopback test will send test packets from the adapter through the adapter's receive circuitry and logic. It may have failed due to the chipset not supporting the test feature.
Were you running diagnostics to test for an existing issue, and can you explain the issue? To further address the issue please provide the
System Support Utility logs. This will not collect any personal information.
- Download and run the .exe from the link above
- Check "everything" then click "scan"
- When scan is finished click "next"
- Save the log and attach it to a post
The
FAQs have additional information about this utility. If you have any questions please do not hesitate to contact us.
Best regards,
Daniel D
和逻辑从适配器发送测试数据包。
这不会收集任何个人信息。
以上来自于谷歌翻译
以下为原文
Hello Noobabooba,
The
Best regards,
Daniel D
