SMC +相位参考校准,提供了一种校准各个接收器的相位响应的方法,但不是绝对相位。
所以即使在校准之后,起始阶段也是随机的,但是表征了从一个频率到下一个频率的相位差。
当您使用SMC进行群延迟测量时,SC21相位响应被标准化为扫描中的一个点。
标准化为的点实际上是设置对话框中的设置之一(见下文)。
一旦相位响应被归一化,我们就可以使用以下公式计算群延迟:!https://dl.dropboxusercontent.com/u/87949221/Forum/ThreadID_118944/GroupDelay.png!
所以,不 - 你没有得到绝对的群体延迟。
你得到的是归一化相位响应的群延迟。
但是,如果您对AM / PM测量感兴趣,那么起始相位值并不重要。
你所需要的只是相对于功率变化的相位变化。
此外,由于AM / PM是在单一频率下测量的,因此您甚至不需要第一层相位参考校准(除非您还想测量群延迟)。
如果您只对AM / PM感兴趣,那么只需进行正常的SMC校准,但只需启用通道中的相位测量并设置功率扫描。
!HTTPS://dl.dropboxusercontent.com/u/87949221/Forum/ThreadID_118944/SMCPhase.png!
以上来自于谷歌翻译
以下为原文
the SMC + Phase Reference cal, provides a way to calibrate the phase response of the individual receivers, but not the absolute phase. so even after calibration, the starting phase is random, but the phase difference from one frequency to the next is characterized. when you make the group delay measurements with SMC, the SC21 phase response is normalized to one of the points in the sweep. the point that you normalize to is actually one of the settings in the setup dialog (see below). Once the phase response is normalized, we then compute the group delay by using the equation:
So, no - you don't get the absolute group delay. what you get is the group delay of a normalized phase response. However, if you are interested in an AM/PM measurement, then the starting phase value is not important. all you need is the change in phase relative to change in power. Also because AM/PM is measured at a single frequency, you don't even need the 1st tier phase reference calibration (not unless you also want to measure the group delay). if you are only interested in AM/PM, then just do a normal SMC calibration, but just enable the Phase measurement in your channel and setup your power sweep.
!https://dl.dropboxusercontent.com/u/87949221/Forum/ThreadID_118944/SMCPhase.png!
你得到的是归一化相位响应的群延迟。
以上来自于谷歌翻译
以下为原文
