Cypress技术william hill官网
齐镭
7年用户 141经验值
CyPress Benicia USB启动设备
大家好,我遇到了一个关于CYUB3014的问题。
我设计了一个带有CYSUB3014 BZXI的PCB,PCB的示意图几乎是我以前的项目复制的(项目中CYUSB3014的一部分工作得很好)。
所以最近我开始调试我的新PCB。
我检查了CYUSB3014(VBUS,1.2V,3.3V)的电压,检查了没有短路的PMODE引脚。
pMOD[2:0]=0Z1为SPI开机。(PMODE引脚上拉/下注册与FPGA没有连接)
当我在威廉希尔官方网站 板上插入USB 3.0电缆时,“CyPress贝尼西亚USB启动设备”显示在控制中心的列表上。这是非常奇怪的,因为我以前从未见过这个信息(我已经设计了几个关于CYUB3014的PCB,所有的工作都很好)。
然后尝试将SLAVEFIFO.IMG编程为SPI,控制中心显示“SPI FLSH编程成功”。
我回复了有线电视,但“CyPress贝尼西亚USB启动设备”仍然显示在名单上……
我检查了两个相同的板,现象是一样的。
因此,我有一些尝试:
1。更改新的SPI闪存
2。交换SPI闪存在我以前的项目以前的董事会和新的董事会
三。将pMOD[2:0]改为Z11
上述尝试已经尝试过,但“CyPress贝尼西亚USB启动设备”仍然显示在名单上……
所以…我不知道问题在哪里。
有人能给我一个提示吗?
谢谢!!
以上来自于百度翻译
     以下为原文
  Hello everyone, I am stuck on a problem about cyu***3014.
I designed a PCB with cyu***3014-BZXI , the schematic of the PCB is almost copied by my previous project (the part of cyu***3014 in that project was working well so far).
So recently I start to debug my new PCB.
I have checked the voltage of cyu***3014 (vbus, 1.2v, 3.3v), have checked pmode pins without short circuit.
The pmode[2:0]  = 0Z1 for SPI boot first.(pmode pins are pull UP/DOWN with register and no connected with fpga)
When I plug u***3.0 cable on the board, 'Cypress Benicia USB Boot Device' is shown on the list in Control Center. This is very strange because I never seen this info before( I have desinged several PCB about cyu***3014 and all work well ).
Then I try to program Slavefifo.img to SPI, and the control center shows "programing of SPI FLSH succeeded".
I replug the cable but 'Cypress Benicia USB Boot Device' still show on the list......
I checked two same board , the phenomenon are same.
Therefore, I have some attempt :
1. change new SPI FLASH
2. exchange SPI FLASH between previous board of my previous project and new board in this time
3. change pmode[2:0] to Z11
The above attempts have been tried but 'Cypress Benicia USB Boot Device' still show on the list......
So... I have no idea where the problem might be.
Could anyone give me a cue for this?
thanks!!
回帖(2)
潘沪城
2018-11-16 15:14:00
嗨,李中伟,
你能上传整个固件项目吗?我可以在我身边测试。
以上来自于百度翻译
     以下为原文
  Hi Lizhong Wei,
Can you upload the whole firmware project? I could test on my side.
李月如
2018-11-16 15:31:18
你好,
如果PMODE引脚没有正确设置,该设备可能会出现为CyPress贝尼西亚启动设备。
在启动过程中,请检查SPI时钟线,以便确认是否有任何活动。(如果PMODE引脚被正确设置为SPI引导,您应该在时钟线上看到活动)。
以上来自于百度翻译
     以下为原文
  Hello,
If the PMODE pins are not set correctly, the device may appear as Cypress Benicia Boot Device.
Please probe the SPI Clock line during boot up so that you can confirm whether there is any activity. (You should see activity on the clock line if the PMODE pins are set correctly to SPI boot).
