在您的图像ACE_0.png中,您应该选择*更改属性*并取消选中“*自动识别此仪器*”,因为连接专家将仅使用** IDN?*查询来识别本仪器无法理解的仪器。
一旦你这样做,你应该看到红色的X消失,你应该看到绿色的支票。
然后,您可以在窗口顶部附近的图标功能区中选择* Interactive IO *以与之通信。
在您的图像ACE_1.png中,您有两个问题:1)您输入了“* GPIB0 :: 10:INSTR *”而不是“* GPIB :: 10 :: INSTR *”。
2)您不能使用** IDN?*与本仪器通信,您需要使用* ID?*查询来识别它。
麦克风
以上来自于谷歌翻译
以下为原文
In your image ACE_0.png you should select *Change Properties* and uncheck "*Auto-identify this instrument*" as the connection expert will only use the **IDN?* query to identify instruments, which this instrument does not understand. Once you do so you should see the red X go away and you should see a green check instead. THEN you can select the *Interactive IO* in the icon ribbon near the top of the window to talk to it.
In your image ACE_1.png you have two problems: 1) You have entered "*GPIB0::10:INSTR*" instead of "*GPIB::10::INSTR*". 2) You cannot use **IDN?* to communicate with this instrument, you need to use the *ID?* query to identify it.
Mike
麦克风
以上来自于谷歌翻译
以下为原文
Mike
