是德科技
杜美娜
7年用户 178经验值
9404示波器能测量直方图吗
嗨,我有一个9404示波器,我想产生一个测量的直方图,即上升时间。
可能吗?
我可以得到测量及其基本统计数据,最大平均值等,但希望能够直观地表示其传播。
谢谢Derek P.S.
为什么我需要启用两个通道才能获得直方图?
以上来自于谷歌翻译
     以下为原文
  Hi
I have a 9404 scope and I want to produce a histogram of a measurement, i.e. rise time.
Is it possible?
I can get the measurement and its basic stats, min max average etc but would like to have a visual representation of its spread.
Thanks
Derek
P.S. Why do I need two channels enabled to get a histogram ?
回帖(1)
周菊
2018-12-25 16:33:03
“我有一个9404示波器,我想生成测量的直方图,即上升时间。是否可能?”
- 是的,如果您有任何可选的EZJit软件包,您可以浏览一个向导,并在10-15秒内在屏幕上进行测量。
如果您没有任何这些软件包,可以从安捷伦网站获取免费的30天许可证,http://www.home.agilent.com/agilent/product.jspx?nid = -35491.536883514.00&
lc = eng& cc = US“为什么我需要启用两个通道才能获得直方图?”
- 你不应该。
你在做什么,纵向或横向?
作为旁注,你有什么版本的S / W?
最新的是4.20.0005(WinXP)或4.50.0008(Win7)。
如果需要,您应该更新。
以上来自于谷歌翻译
     以下为原文
  "I have a 9404 scope and I want to produce a histogram of a measurement, i.e. rise time. Is it possible?"
- Yes, if you have any of the optional EZJit packages, you can walk through a wizard, and have a measurement on-screen in 10-15 seconds. If you don't have any of those packages, you can get a free 30-day license from the Agilent website, http://www.home.agilent.com/agilent/product.jspx?nid=-35491.536883514.00&lc=eng&cc=US
"Why do I need two channels enabled to get a histogram ?"
- You shouldn't. What are you doing, vertical or horizontal?
As a side comment, what version of S/W do you have? The latest is either 4.20.0005 (WinXP) or 4.50.0008 (Win7). You should update if you need to.
Al
