赛灵思
古克满
7年用户 240经验值
Xilinx设计工具程序无法从Windows程序访问
你好,
我是一个全新的用户。
我已下载并安装了ISE 14.7并通过email收到了Lic文件.Xilinx设计工具程序无法从Windows程序访问,它作为exe文件安装在Xilinx文件夹中。
我运行了ISE.exe但收到了许可证未找到错误。
消息说许可证配置管理器将启动但不会启动。
我试图从exe文件运行它,并在ISE下拉菜单没有运气。
我将lic文件复制到C:。Xilinx文件夹(我已经附加了文件)。
我正在运行Windows 7 64位。
谢谢您的帮助!
卡里
Xilinx.lic 1 KB
以上来自于谷歌翻译
以下为原文
Hello,
I am a brand new user. I have downloaded and installed ISE 14.7 and received the Lic file via email. Xilinx Design Tools program is not accessible from windows programs, it installed as exe files in the Xilinx folder. I ran ISE.exe but received a license not found error. The message says that the license configuration manager will launch but it does not. I have tried to run it from the exe files, and drop down menu in ISE with no luck. I copied the lic file to C:.Xilinx folder (I have attached the file). I am running Windows 7 64-bit.
Thanks for the help!
Cary
            Xilinx.lic ‏1 KB
回帖(9)
刘鹏
2018-12-26 11:57:01
您好,是否安装了该工具?
你可以打开命令promt并键入xlcm这将打开许可证管理器,然后只需通过查找现有许可证 -  Pratham浏览到许可证文件
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello,
Is the tool installed? can you please open a command promt and type xlcm this will open license manager and then simply browse to the license file via locate existing license
-Pratham
-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
----------------------------------------------------------------------------------------------View solution in original post
刘鹏
2018-12-26 12:13:05
您好,是否安装了该工具?
以上来自于谷歌翻译
以下为原文
Hello,
-Pratham
-Pratham
李建设
2018-12-26 12:23:07
请查看以下帖子.http://forums.xilinx.com/t5/Installation-and-Licensing/Licensing-problem-with-Webpack-ISE/m-p/361287#M5087Thanks
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
以上来自于谷歌翻译
以下为原文
Please check the following post.
Thanks-------------------------------------------------------------------------
Don’t forget to reply, kudo, and accept as solution.
马海娟
2018-12-26 12:28:44
嗨Pratham,
感谢您的帮助!
您的解决方案有效,但我找到许可证管理器的文件夹是C: Xilinx  14.7  ISE DS  common  bin  nt64
问候,
卡里
以上来自于谷歌翻译
以下为原文
Hi Pratham,
Thank you for the help! Your solution worked exept the folder where I found the licence manager was C:Xilinx14.7ISE_DScommonbinnt64
Regards,
Cary
