我在实验室计算机上安装Xilinx 11.2版时遇到问题。
我从Xilinx设计工具网站下载了用于32位Windows系统的11.2 ISE设计套件,我下载的名为“Xilinx_11.2_ISE_DS_nt”的解压缩文件夹文件是4.17 GB文件夹。
此文件夹中是否有某个目录或可执行文件将安装Xilinx 11.2?我尝试在此目录中打开名为“xsetup.exe”的可执行文件:“Xilinx_11.2_ISE_DS_nt direct swhelp ise11 112_ise wu replace installer”
但每当我打开可执行文件时都没有任何事
Xilinx 11.2无法安装。
我还要提一下,Xilinx 10.1目前已安装在实验室计算机上;
如果我们试图在同一台计算机上安装Xilinx 11.2,我不确定这是否会导致问题。
此致
兰迪
Umich EE Class 2011
以上来自于谷歌翻译
以下为原文
I'm having trouble installing Xilinx version 11.2 on our lab computer. I downloaded the 11.2 ISE Design Suite for a 32-bit Windows system from the Xilinx Design Tools website, and the unzipped folder file I downloaded called "Xilinx_11.2_ISE_DS_nt" is a 4.17 GB folder. Is there a certain directory or executable within this folder that will install Xilinx 11.2?
I tried opening the executable called "xsetup.exe" in this directory:
"Xilinx_11.2_ISE_DS_ntdirectswhelpise11112_isewureplaceinstaller"
but nothing happens whenever I open the executable; Xilinx 11.2 does not install. I should also men
tion, Xilinx 10.1 is currently installed on the lab computer; I'm not sure if that would cause problems if we are trying to install Xilinx 11.2 on the same computer.
Sincerely,
Randy
Umich EE Class of 2011
