嗨@ mm035b,
是的,您将能够使用Xilinx工具打开设计并在任何支持的操作系统中进行修改,这应该不是问题。
话虽如此,我相信Virtex 5将使用ISE Design Suite。
ISE 14.6不正式支持Win10(请参阅支持的操作系统的链接)。
我建议您继续使用Win7 OS系统中的ISE设计,因为很多时候可能会发生崩溃和其他环境问题。
其他一些有用的链接:Link2 - Vivado支持7系列及更高版本,Link3 - Vivado支持的操作系统包括Win10 Pro。
问候,Prathik -----------------------------------------------
------------------------------------------------请注明
适当的帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。给予您认为有用且回复导向的帖子。感谢.----------------
以上来自于谷歌翻译
以下为原文
Hi @mm035b,
Yes, you will be able to use your Xilinx tools to open the design and modify in any supported OS which should not be a problem.
That being said, I believe for Virtex 5 you will be using ISE Design Suite. Win10 is not officially supported for ISE 14.6 (See link for supported OS). I suggest you should continue using the ISE designs in Win7 OS system else as seen many times there are chances of crashes and other environment problems to occur.
Some other useful links: Link2 - Vivado supports 7-series and above, Link3 - Supported OS for Vivado includes Win10 Pro.
Regards,
Prathik
Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query.
Give Kudos to a post which you think is helpful and reply oriented.
嗨@ mm035b,
以上来自于谷歌翻译
以下为原文
Hi @mm035b,
Regards,
Prathik
