嗨
不确定您使用的是哪个版本的ISE,但每个版本都有安装和发行说明。
有一个表格讨论了Webpack和ISE Design Suite的架构支持,如本文档第18页所示。
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_4/irn.pdf
你可以看看你正在使用的ISE webpack的irn。
一旦卸载ISE,您是否可以删除安装文件夹中的剩余文件夹(如果有),并尝试再安装一次。
--hs
--------------------------------------------请注意 - 请注明
如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K--
以上来自于谷歌翻译
以下为原文
hi
not sure which version of ISE you are using, but there is a installation and release notes for each release.
There is a table that talks about architecture support for Webpack and ISE Design Suite as shown in page 18 of this document. http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_4/irn.pdf
you can look at the irn of the ISE webpack you are using.
also once you uninstall the ISE, can you delete the remaining folders if any in the installation folder and try installing one more time.
--hs
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
嗨
--hs
以上来自于谷歌翻译
以下为原文
hi
--hs
