赛灵思
王文霞
7年用户 192经验值
ISE 12.1中的基本位有什么可用信息?
你好,
我想知道ISE-12中的“基本位”功能是否有任何可用信息?
据推测,此功能应该允许设计人员知道他们的设计使用了多少总配置位。
就像为SEUPI工具引入的“关心位”一样
任何有关此事的帮助将不胜感激
谢谢
以上来自于谷歌翻译
以下为原文
Hello,
I want to know if there is any information available on the "essential bit" feature in ISE-12?  supposedly this feature should allow  designers to know how much of the total configuration bits is utilized by their designs. just like "care bits" introduced for SEUPI tool
Any help on this matter would be appreciated
Thanks
回帖(1)
潘晶燕
2019-1-11 11:19:55
R,
联系您的Xilinx FAE。
旧的“SEUPI”软件做了类似的事情,“COSMIC”程序进行了数值估算。
“基本位”旨在取代这两种旧工具。
已经做了大量工作来验证其准确性,因此它将所有可能修改功能行为的位标记为必要,而不是标记不改变功能的其他位。
仍然是软件无法确定您的设计功能是否被修改的情况。
一个很好的例子是MicroBlaze(tm)设计中堆栈指针的地址位:如果你从未深入到堆栈中,你永远不会知道地址位是否被破坏。
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
r,
Contact your Xilinx FAE.
The old "SEUPI" software did something similar, and the "COSMIC" program gave a numerical estimate. The "essential bits" is intended to replace both of those older tools.  A great deal of work has been done to verify its accuracy, so it marks all bits that could modify the functional behavior as essential, and not mark other bits which do not change the function.
It is still the case that the software can not determine if the function of your design is modified or not.
A good example is address bit <3> of the stack pointer in a MicroBlaze(tm) design:  if you never get that deep in the stack, you would never know that address bit <3> is broken, or not.
Austin Lesea
Principal Engineer
Xilinx San Jose
