我和H-Bridge'VNH5180A'进行了交互。我试图找到问题好几天了,但我找不到它。
H桥的输出电压不正确。
在桥的Pins是这些电压。我用示波器测量它们:
指定
电阻前的电压
H桥引脚的电压
CS
CS_DIS
EN_A
五
五
在一个
EN_B
五
五
IN_B
3,3
3,3
OUT A | MOTOR1
DutyCycle 50%| 8 kHz | 0-0,5V
OUT B |电机2
12
12
PWM
DutyCycle 50%| 8kHz | 3,3V
DutyCycle 50%| 8kHz | 0-3,3V
VCC
12
12
附图是我的布局图,H-Bridge的数据表和H-Bridge输出Out_A -Out_B的Osziloscop图片。
感谢您的帮助。
#vnh5180 #h-bridge #h-bridge
以上来自于谷歌翻译
以下为原文
I having traouble with the H-Bridge 'VNH5180A'. I tried to find the problem now for some days, but I wasn't able to find it.
The H-Bridge haven't the right output voltage.
At the Pins of the Bridge are these voltages. I measured them with an oscilloscope:
designa
tion
Voltage before the resistors
Voltage at the pins of the H-Bridge
CS
CS_DIS
EN_A
5
5
IN_A
EN_B
5
5
IN_B
3,3
3,3
OUT A | Motor1
DutyCycle 50% | 8 kHz | 0-0,5V
OUT B | Motor2
12
12
PWM
DutyCycle 50% | 8kHz | 3,3V
DutyCycle 50% | 8kHz | 0-3,3V
Vcc
12
12
Attached is a picture of my layout, of the datasheet from the H-Bridge and an Osziloscop picture of the H-Bridge output Out_A -Out_B.
Thanks for your help in advance.
