是德科技
张荷
7年用户 220经验值
PNAX源功率校准怎么连接
如果尝试进行源功率校准,则对话框中的注释为“与DUT建立所有连接以及测量设置所需的组件/仪器”,然后单击“确定”继续...如果所有连接均为
DUT到位了,功率计会去哪里?如果我在没有错误信息的情况下越过下一个点,它是否还会测量输出端口的音量?
以上来自于谷歌翻译
     以下为原文
  If one tries to do a Source Power calibration, the comment in the dialog box is " Make all the connections to the DUT and the necessary components/instruments for your measurement setup, and click OK to continue...
If all the connections for the DUT are in place, where would a power meter go?  If I were to get past the next point without an error message, will it also measure the power for the output port tickler tone(s)?
回帖(1)
仲娜娜
2019-1-30 14:15:38
仅供上下文使用 - 您正在讨论来自NVNA的提示。
在NVNA中,使用校准的PNA接收器执行功率校准。
在功率校准期间,您不使用功率传感器。
在校准向导过程中执行接收器校准时,您已使用过功率传感器。
您希望连接DUT的原因是功率校准会根据DUT的匹配而改变。
根据不匹配情况,这可能会对输入功率的平坦度产生重大影响。
关于你的第二个问题:“它还会测量输出端口的音量”:答案是肯定的......在功率校准期间,NVNA将在所有频率下以所需功率电平调节所有音调的功率。
以上来自于谷歌翻译
     以下为原文
  Just for context - you are discussing a prompt from NVNA.
In NVNA, the power calibration is performed using your calibrated PNA receivers. You do not use a power sensor during the power calibration.
You already used the power sensor when you performed the receiver calibration during the cal wizard process.
The reason that you want to have the DUT connected is that the power calibration changes based on the match of the DUT. Depending on the mismatch, this could have a significant impact on the flatness of your input power.
As for your second question: "will it also measure the power for the output port tickler tones": the answer is yes... During the power calibration, NVNA will level the power of all tones at all frequencies at the desired power levels.
