我将遵循V1.06教程来理解正在做什么,以及所有的事情是如何组合在一起的。一旦你做了,验证演示工作。现在重复同样的步骤,但是使用V2.0和谐。2有很多命名差异,所以最好重复设置,但是让和声做所有的代码。设置。尝试将V1.06移植到V2.0是我的能力,因此当你头脑中一切都新鲜的时候,更容易重复。
以上来自于百度翻译
以下为原文
I would follow the v1.06 tutorial to understand what is being done, and how everything comes together.
Once you have done that, verify the demo works.
Now repeat the same steps, but using v2.0 Harmony.
2.0 has a bunch of naming differences, so best to repeat the set up but let Harmony do all the code set up. trying to port v1.06 to v2.0 is beyound my ability, hence much easier just to repeat when everything is fresh in your mind.
以上来自于百度翻译
以下为原文
