Microchip
黄辉
7年用户 231经验值
无法从MPLAB-X导入hex文件
我试图从MPLAB-X 3.45的DISTDELATE 生产目录导入一个十六进制文件。目标是PIC32 MX350F256H,我可以通过PICtiT3编译、编程并从MPLAB-X运行。我没有运行调试会话。我需要把我的HEX文件发电子邮件给国家的另一端的人,这样他们就可以通过他们的PICTIT3把它加载到他们的硬件拷贝中。听起来很简单,我以前总是在MPLAB8中使用PIC32 MX系列。所以我认为MPLABX-IPE是一个很好的工具。我可以用MPLABX-IPEI连接到我的PACTIT3。但是当我在IPE 3.45中导入HEX文件时,它会弹出一个弹出消息“导入的HEX文件包含调试信息,并且已经被MPLABX IPE清除”。唯一可用的选择是“OK”,它让您在输出窗口中加载“加载十六进制文件”。请等等……“永远。你知道我做错了什么吗?”
以上来自于百度翻译
      以下为原文
    I'm trying to import a hex file from distdefaultproduction directory of MPLAB-X 3.45.  The target is a PIC32MX350F256H, which I can compile, program, and run from MPLAB-X via PICkit3.  I am not running a debug session.  I need to email my hex file to people on the other side of the country so they can load it into their copy of the hardware via their PICkit3.  Sounds simple enough, I used to do it all the time in MPLAB8, with PIC32MX family.  So I thought MPLABX-IPE would be a good tool for them.
I can connect to my PICkit3 with MPLABX-IPE.
But when I do File-Import-Hex in IPE 3.45, it gives me a pop-up message "The imported hex file contained debug information and has been cleared by MPLABX IPE".  The only available choice is "OK" which leaves you at the Output window with the message "Loading hex file. Please wait..."  forever.
Any idea what I am doing wrong?
回帖(5)
杨叶
2019-5-8 10:46:58
嗨,在MPLAX中,也可以创建一个包含HEX文件的项目:http://MyCHIPCDeavest.Abx:Projest-PrimBug。
以上来自于百度翻译
      以下为原文
    Hi,
In MPLAB X it is also possible to create a projetc which contains only an hex file : http://microchipdeveloper...abx:projects-prebuilt.
You attach the file under "loadable" in the project tree
Regards
石双厚
2019-5-8 10:53:17
你好,Vloki,你是对的,我不知道MPLABX的项目菜单。MPLABX 3.45中的任何地方都找不到“导出十六进制”。也许它是在一个新版本中添加的?我现在不敢更新,我已经完成了一个项目。当然有很多东西要学,但这是乐趣的一部分。我想MPLABX最终会成为我的朋友。
以上来自于百度翻译
      以下为原文
    Hello good people,
Vloki, you are correct, I do not know the project menu of MPLABX.  I can't find "Export Hex" anywhere in MPLABX 3.45.  Maybe it was added in a newer version?  I don't dare update now, I'm halfway into a project.  There sure is a lot to learn, but that is part of the fun.  I think MPLABX will be my friend eventually.
王焕树
2019-5-8 11:12:25
MPLABX是专门为支持同时安装的多个版本而设计的。不需要删除一个版本来安装下一个版本,它们在安装了新版本之后都可用。
以上来自于百度翻译
      以下为原文
MPLABX is specifically designed to support multiple versions installed at the same time.
You do NOT need to remove one version to install the next, and they will both be available after you have installed the newer version.
王竹
2019-5-8 11:27:27
不,从一开始就在那里。遵循上面的链接。在弹出式菜单中,如果您右键单击一个PyJekts名称,您将找到导出条目!这里显示的是“包”上面的四个位置:http://MyCHIIPDeavest.PLABX:项目包
以上来自于百度翻译
      以下为原文
    No it was there from the beginning. Follow the link above. In the pop-up menu that appears if you right click a Projekts Name you will find the export entry!
It is four positions above "package" shown here:
http://microchipdeveloper...plabx:projects-package
