Microchip
刘龙飞
7年用户 257经验值
PICKIT 3读取所有目标设备ID为0000000
大家好,我面临着以下问题:MCU:PIC24FJ256GA406Programmer:PICKIT 3During MPLAB X IDE 3.5中的编程过程,在PICKIT3日志窗口中显示以下消息:“目标设备ID(0x0)是无效的设备ID。请检查到目标设备的连接“MCU是单独构建的,除了推荐的最小连接外,没有外部组件(用户手册第2.0章,图2-1))——配置位(FICD)设置为PGx1(连接到PGEC1和PGED1)——我们还尝试了默认的PGx3(与PGEC3和PGED3连接)——Internal振荡器选择PICKit编程器电源目标设置为3.0V(无外部电源)-外部3.0V电源(PICKit电源目标未选中)-故障单片机(2次更换)我们欢迎任何有用的建议。预先感谢你。最好的问候。
以上来自于百度翻译
      以下为原文
    Hello Everyone,
I am facing with the following problem:
MCU: PIC24FJ256GA406
Programmer: PICKIT 3
During the programming process in the MPLAB X IDE 3.5 the following message appears in the PICKIT3 log window:
"Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device."
- The MCU is built separately with no external components except the recommended minimum connections (User manual Chapter 2.0, Figure 2-1)
- The Configuration Bits (FICD) are set to PGx1 (connected to PGEC1 and PGED1)
- We tried out the default PGx3 also (with PGEC3 and PGED3 connected)
- Internal oscillator selected
PICKit programmer Power Target set to 3.0V (with no external Power)
- External 3.0V power supply (PICKit power target unchecked)
- Failed MCU out of the question (2 times replaced)
We are welcome any useful recommendations.
Thank you in advance.
Best Regards.
回帖(4)
傅双育
2019-5-17 15:31:05
你有所有的VDD和VSS管脚连接吗?在PGC/PGD/MCLR上是否有任何组件,如果是这样的话,可能是问题所在。
以上来自于百度翻译
      以下为原文
    Do you have all Vdd and Vss pins connected?
Do you have any components on PGC/PGD/MCLR if so that could be the problem.
陈晨
2019-5-17 15:36:06
MCU是独立建造的,除了推荐的最小连接外,没有外部组件。你核实过Vcc吗?
以上来自于百度翻译
      以下为原文
Does this include all the required capacitors?
Did you verify Vcc?
王焕树
2019-5-17 15:54:28
显然这个问题已经解决了,但是OP在别人的主题中公布了他们的解决方案。http://www..hip.com/for./FindPost/969800
以上来自于百度翻译
      以下为原文
    Apparently this issue has been solved, but the OP posted their solution in someone else's topic.
http://www.microchip.com/forums/FindPost/969800
张丽雯
2019-5-17 16:09:50
……劫持一个3岁的线索。叹息。
以上来自于百度翻译
      以下为原文
...by hijacking a 3-year-old thread.
Sigh.
