ST意法半导体
申志敏
7年用户 199经验值
上电后LIS2DM的电流消耗约为100uA?
连接是:
Pin1:外部4K7至3V的SCL
Pin2:外部4K7至3V的SDA
Pin3:SA0连接到GND
Pin4:/ CS连接到3V
Pin5:INT2打开
Pin6:INT1到输入端口uP
Pin7,8:3V
Pin9-14:GND
可能是Pin3上有一个内部上拉,我应该将SA0线连接到3V以获得低功耗?
#lis2dm-I2C-SA0
以上来自于谷歌翻译
以下为原文
after power up the LIS2DM the current consumption is about 100uA ?!
The connection is:
Pin1 : SCL with a external 4K7 to 3V
Pin2 : SDA with a external 4K7 to 3V
Pin3 : SA0 connected to GND
Pin4 : /CS connected to 3V
Pin5: INT2 open
Pin6: INT1 to Input Port uP
Pin7,8: 3V
Pin9-14: GND
Could it be that there is an internal pull-up on Pin3 and I should connect the SA0 line to 3V to get a low power consumption ?
#lis2dm-i2c-sa0
回帖(1)
郝汉
2019-5-23 14:42:11
我们遇到了与LIS3DH相同的问题。 SA0具有内部上拉。如果你接地,你将获得额外的电流。我们将它浮动以在I2C总线上设置地址位= 1。
以上来自于谷歌翻译
以下为原文
We encountered the same problem with the LIS3DH.  The SA0 has an internal pull up.  If you ground it you will draw the extra current.  We float it to set that address bit = 1 on the I2C bus.
