亲爱的Manas,
如果USB插件的LED是,我已经同意,在我的PC,有“1.2 驱动”文件夹下的“程序文件 CyPress文件夹”。
但是,如果我插入或退出USB电缆,对PC的“设备管理器”没有影响,我们知道如果PC识别USB设备,“设备管理器”将刷新,如果设备插件!
我找不到关于如何使用DVK板和如何设置软件环境的指南,这样开发人员就可以开发固件、应用程序等等。所以当我打开位于你的USB套件中的Eclipse IDE并加载CysBueSub的例子时,有很多错误,似乎在SW环境中有错误!
谢谢!
以上来自于百度翻译
以下为原文
Dear Manas,
If the USB plugin the LED is on , and I have confired that in my PC there are have "1.2driver" folder under the "programm filescypress folder " .
But If I plugin or out the USB Cable , there are no effects on the PC 's "devices manager" , we know if the PC indentify a USB device, the "devices manager " will refresh if the device plugout !
I can not find the guide about how to use the DVK board and how to set the software environment so developers can develop the firmware .application and so on .... So when I open the eclipse IDE which located in your USBSuite and loaded the CyUSBSuite example , there are a lot of errors , It seems that there are errors in SW environment !
Thanks!
亲爱的Manas,
谢谢!
以上来自于百度翻译
以下为原文
Dear Manas,
Thanks!
